1997 ford mustang gt 4.6 bad oil leak engine gone? *pics*
Old 11-11-2010, 08:35 AM
mard
mard's Avatar
i've called around for this part "oil filter adapter" auto zone or any of the other auto stores don't got it.. seems i either gotta go with the dealer or the junkyard.. $50 from the junkyard and $180 from the dealership... i called around as well to see how much it would cost to get it installed.. and best i've came up with is $50-$60.. i may have a shop do it for me as i don't have the exact tools do it. from research i did the hole is there stock.. and it is there to let you know it's gone bad.. but if that's the case i think that is horrible.. if you are unaware it went bad and didn't catch the oil leak in your drive way or down the street.. your engine will be gone.
mard is offline
Old 11-11-2010, 08:37 AM
mard
mard's Avatar
i dunno if i'm aloud to post links to other websites here but this is where i found more information about my issue
http://www.modularfords.com/forums/s...filter-adapter
mard is offline
Old 11-11-2010, 03:41 PM
mustangman36578
mustangman36578's Avatar
it is the oil cooler. it comes on cobras. op is your 97 a cobra? that hole is supposed to be there it is a weep hole just like the water pump has. i would not go to a junyard and get one unless money is really tight. you will have to either go to a stealership or try your luck in the parts section on a few different forums. might be one on ebay too.
mustangman36578 is offline
Old 11-11-2010, 05:31 PM
mard
mard's Avatar
my mustang is just a regular gt 4.6
mard is offline
Old 11-11-2010, 05:38 PM
uberstang1
Chupacabra
uberstang1's Avatar
I have an old 2v with, and an old cooler and the one on my 4v I will check to see if it has a weep hole because that hole def looks machined like cliffy said unless its some freak accident.
uberstang1 is offline
Old 11-11-2010, 05:59 PM
FOURSIXALLDAY
FOURSIXALLDAY's Avatar
replace the adapter do not jb weld or anything else the best way is to just replace it. i would do a little bit more research to see what is going on if i were you, because ive never seen something like that bfor. its a perfect hole. its wierd.
FOURSIXALLDAY is offline
Old 11-11-2010, 07:36 PM
yamanx
yamanx's Avatar
If you take off the oil filter are the threads loose on the adapter? I've seen the weep hole leak because the threaded shaft is loose.
yamanx is offline
Old 11-12-2010, 04:31 PM
Rokgtar
Rokgtar's Avatar
Mine leaked like crazy at the same spot - it is a weep hole - and there is a Ford gasket and O-ring kit you can buy from the dealer to repair it. I had a guy who worked for a Ford dealer do it for me on the side and no leak since. Contact the dealer and they should be able to get the kit for you.
Rokgtar is offline
Old 04-07-2014, 11:39 PM
Gera
Gera's Avatar
Default Oil leak
I have the same problem should I just buy a new adapter????
Gera is offline
Old 04-07-2014, 11:43 PM
Gera
Gera's Avatar
I just did that 3 months ago my self then took it to a deal and it just leaked all my oil out
Gera is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
drumhedd2005
08-13-2015 09:59 AM
08-10-2015 01:44 PM
tmdm
08-07-2015 10:24 PM
Quick Reply: 1997 ford mustang gt 4.6 bad oil leak engine gone? *pics*
