Movin Battery to the trunk
I just bought a Battery relocation kit for my 96 Cobra from RPMOutlet. I have a couple of questions.
1. The kit came with a 20ft wire, is that for both positive and negative?
2.Anyone have good advice?
you need like 2 feet to ground the ground terminal on the battery. run the positive line first and if you have slack you can use that, if not go to a stereo supply store and get a couple feet of wire.
not much advice to give, there arent too many ways to do this... only real suggestion i have is make sure the battery is over teh passenger rear tire.
Anyway is fine long as its not rubbing. I ran mine and a buddys under trunk mat under back seat into the plastic molding driver side of rear seat, under the little plastic trim under driver door and behind driver kick panel to firewall... just like a sub install.
also gotta make sure that you run the bolts through the trunk that hold the battery down..requires dropping the tank. the tracks around here check to see if its bolted down correctly. ill post pics off my battery in the trunk and how i ran my wires tomorrow or later tonight if i get time.
