HELP - ODOMETER ALL DASHES - WEIRD BUZZING FROM FUSE PANEL...
Old 12-08-2010, 12:45 PM
jrobinsonchicago
jrobinsonchicago's Avatar
Default HELP - ODOMETER ALL DASHES - WEIRD BUZZING FROM FUSE PANEL...
So I swapped in a new 4.6
I had a bullitt motor and it took a crap. So I bought a standard 4.6 Mustang motor and dropped it in...
I turn the key to accessory and it reads all dashes for the mileage. There is also a weird, loud, constant buzzing coming from the box located in the front passenger fender when the key is turned on, and the PATS / theft light flashes quickly.
It will bump, but it won't turn over.
Any ideas...
jrobinsonchicago is offline
Old 12-08-2010, 03:37 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Did you swap out the PCM or instrument cluster?
You may also have already done so, however double and triple check the wiring and connectors, fuses, etc...
cliffyk is offline
Old 12-08-2010, 04:29 PM
jrobinsonchicago
I didn't swap the cluster and pcm. Same motors were used... Well, mine is a 2001 and the motor is a 2000.
jwog666
12-27-2021 08:09 PM
lincolnshibuya
10-06-2015 08:45 AM
breaking
10-02-2015 01:27 PM
ChampInSD
10-02-2015 04:55 AM
mungodrums
09-28-2015 10:54 PM
Quick Reply: HELP - ODOMETER ALL DASHES - WEIRD BUZZING FROM FUSE PANEL...
