Cam degreeing gurus, please enter.....not an opinion thread LOL
Because I have checked with a compressed lash adjuster and the tightest I am seeing is .045" @ 108. I am not going to call that the clearance until I get in there with an adjustable one so I can set it to zero lash and see exactly where we are.
Official ptv clearance is .025" installed at 107.75 degrees ICL. That was measured at 5 degrees atdc.....everywhere else I had more clearance. I'm not going to even try to get a quarter of a degree to get them in at 108 LOL. If it was a quarter of a degree retarded, I'd probly go over it again and shoot for 108 exactly.
I honestly thought it would be closer than it was. .010" was going to be my "no-go" and would have retarded them accordingly. I had them in at a few different centerlines to see how they did. The clearance was only a couple thousandths more at 109ICL........and really it just changed where (meaning position of the crank) the closest spot was. IIRC, having them at around 110 ICL made the clearance smallest around 15* ATDC and advancing them just made the the clearance smallest closer to TDC. At 110 ICL I was getting in the upper 40 thousandths.........
It's weird because we both have the same intake duration as well. With that in mind you would think the measurements would be very similar at the same ICL. Yet you were getting well over .040" to my .030"-.035" at a 110 ICL.
According to Nick you'll loose like .020"-.030" by advancing the ICL 2 degrees. Like going from a 110 to a 108 for example.
Regardless, it seems to work for your application. I'm anxious to see how it all turns out.
I think bottom line is that every motor is going to be a little different when it comes down to thousandths of an inch. I'm willing to bet that both of our readings are within the average range for these motors.
Anther thing to remember is that when it comes down to thousandths of an inch, everything comes into play including piston manufacturer, head gasket thickness, exact tolerances on machine work and block, etc......all of which can vary slightly. Even some of the components were completely different throughout the years.
I think this is why people note hearing a chattering or valve noise on initial start up and then it goes away. Unfortunately, by the time the adjusters settle back down to provide a true zero lash, the damage to the valves and the marks on the pistons are already present regardless of whether or not the cams actually did clear with the right amount of valve lash.
Daddys Girls GTs
09-14-2015 08:46 PM
