Loud humming noise from Idle Air Control valve?
Old 03-05-2011, 04:49 AM
Mr.SVT
Mr.SVT's Avatar
Thanks
Mr.SVT is offline
Old 03-05-2011, 07:57 AM
Mr.SVT
Mr.SVT's Avatar
I have a 2001 cobra can anybody tell me where the IAC is I can't fine any youtube video of someone changing it or whatever please help
Mr.SVT is offline
Old 03-05-2011, 07:59 AM
Mr.SVT
Mr.SVT's Avatar
it sounds like it coming from the back of the motor like the bottom
Mr.SVT is offline
Old 03-31-2018, 01:22 PM
JRJ
JRJ's Avatar
Yep, I currently have the same problem with my 1996 GT single overhead cam. It'll intermittently rev up to 2k rpm with loud humming noise for a few seconds, then die. Cranks right back up, but it's embarrassing. Wife wants a reliable ride, and so do I. I cleaned the IAC valve to save money, but that didn't fix it. Some people I spoke to thought it could be a vacuum leak, but I don't know where to start with replacing hoses. However, I do know how to replace the IAC valve. Also considering replacing the throttle position sensor while I'm in there. Not sure if it's worth the money, though.
JRJ is offline
Old 03-31-2018, 01:36 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
THe humming/honking sound is as I explained here an indication that the IAC is worn to the point of failure--as it is worn, not dirty, so no amount of cleaning will fix it.
It is very rare for the TPS to fail, i.e. I would not replace it just for the sake of doing so--just throwing parts at a problem is never a good strategy...
cliffyk is offline
Old 04-01-2018, 09:08 AM
JRJ
JRJ's Avatar
Thanks for the advice, Cliff. I'll replace the IAC valve and save the cash on the TPS.
James
JRJ is offline
Old 04-01-2018, 10:34 AM
Brad1405
Brad1405's Avatar
I replaced the IAC with a remanufactured one and it didn't fix it. I bought a brand new one and that solved the problem. Takes a 8mm socket to remove the bolts I believe. It's been about 7 years ago that I posted this.
Brad1405 is offline
2007StangV6
01-28-2016 06:09 PM
zanemoseley
09-06-2015 12:58 PM
Emblazoned
09-03-2015 10:45 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Loud humming noise from Idle Air Control valve?
