tr-3650 power limits
It'll be close. I think 375 TQ is the recommendation for the 3650? If I'm wrong I'm sure someone will blast me for it on here. It'll come down to how much you beat on it at this point as far as how long it will last though.
They are rated for 360ft/lbs at the crank, which is roughly 315rwhp. They don't last long with any sort of aggressive driving once a power adder is part of the equation. You CAN swap out the input shaft for a hardened 26-spline unit. The input shaft is the weakest link on the 3650 in stock form. With a hardened 26-spline unit, they can handle quite a bit of abuse. Being an 03, you have a pretty good version of the 3650, but they do have weaker shift forks and synchros than the 04s. By the time you end up beefing up the 3650, you could have already bought a t56 in a lot of cases.
Take that for what it's worth, I used to have one myself and was looking into building mine, but it just wasn't worth all the money. They are a pretty complicated trans to build from a manual gearbox standpoint and they cost a lot of moneys!! I know liberty transmission and (I think promotion) sell a hardened input shaft as well as a kit that updates the synchros and shift forks to the 04 specs.
Sort of a sidenote, here's some info from the RedBook, that might be of interest, about the trannies in our cars:
Also, here is a great article from Transmission Digest providing a good description of the 3650, and comparisons to the T-5/45 and TKO transmissions.
KingRando
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
09-25-2015 06:58 PM
