Uh-oh, an oil leak has made itself known, any thoughts? - MustangForums.com
Old 10-26-2015, 03:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Old 03-12-2011, 09:21 PM   #1
tracyballard
tracyballard's Avatar
Default Uh-oh, an oil leak has made itself known, any thoughts?
I just figured out that my 2002 Mustang GT has a pretty bad leak, but one that only happens when the engine is fully warmed up as far as I can tell so far. It looks like it's coming from middle of the car, right under the transmission housing - could be the tranny or maybe just dripping down from the engine and running off the lowest point. It seems to be a pretty light oil, didn't look or taste like antifreeze or auto trans fluid, but this has a manual transmission and I'm not really familiar with what manual transmission oil would be like - is it a light or heavier oil?? any ideas??? thanks in advance!
tracyballard is offline   Reply With Quote
Old 03-12-2011, 10:56 PM   #2
96meangreengt
96meangreengt's Avatar
Quote:
It sounds like where its coming from it would be the rear main seal leaking. as far as the oil being a light color maybe the oil has been changed recently and is still a light color.
For future reference if you dont know what it is dont taste it lol.
96meangreengt is offline   Reply With Quote
Old 03-12-2011, 10:59 PM   #3
tracyballard
the engine oil itself is pretty light colored. so, you think it's the rear seal? that sounds pretty bad. I've added a quart or 2 once in the 6 weeks I've had it, and I haven't noticed a low level, it actually still seems a little higher than it should be, but this dipstick is kind of hard to read, it's hard to get a fresh level mark without oil trailing up the dipstick above the level mark.
Old 03-12-2011, 11:06 PM   #4
96meangreengt
since you just got the car I would go ahead and just change the oil and filter that way you know how much oil you put in and how much you are losing. As far as the oil trailing up the dipstick how long are you waiting after you shut down the engine to check it? If you dont wait 5 mins or so you can get inaccurate readings.
Old 03-12-2011, 11:08 PM   #5
tracyballard
I generally check it on a cold engine, or wait at least 10 or 15 minutes if I've had it running to check, and I check multiple times to try to get a clear reading. I used to be a heavy line mechanic pulling and rebuilding engines, but diagnosis is not really my best skill.
Old 03-14-2011, 06:46 AM   #6
uberstang1
Chupacabra
uberstang1's Avatar
Is the oil coming from inside the bellhousing? or is it running from the top of the bellhousing, if its from inside the belhousing it can only be the rear main seal or in a ver very rare case an oil gallery plug (but u would be losing oil pressure in case of a gallery plug) it its running down from the top of the bellhousing its probably the back of the valve cover.
uberstang1 is offline   Reply With Quote
Old 03-14-2011, 10:03 AM   #7
tracyballard
I'll have to check into that, maybe later today. I've had it sitting in the driveway without starting it since Saturday, and I haven't really driven it since Friday night, and there's not a single drop under it. But when it was warmed up good with a few minutes of stoplight flogging, it leaked a big spot in a couple of hours that was about a foot wide by 3 feet long. After cooling down for a couple of hours the leak stopped. I started it up to drive it to a new spot on the driveway Saturday and that wasn't enough to get the leak going.
Does anyone know how many book hours a rear seal replacement calls for?
Old 03-14-2011, 12:07 PM   #8
0949er
0949er's Avatar
a lot. it will cost a pretty penny.
Locate the leak first before u put it in a shop
0949er is offline   Reply With Quote
Old 03-14-2011, 02:17 PM   #9
Repzard
Repzard's Avatar
^ I agree .. Rear Main seal, I heard the 302 where known for RMS leaks bad in the day.
Dont hear much about the 281 leaking though.
Guess antifreeze is a good cocktail drink
Repzard is offline   Reply With Quote
Old 03-14-2011, 02:23 PM   #10
Repzard
Repzard's Avatar
My guess would be a average of 5-8 hours depending on Mech shop.
It involves getting tranny out of the way or even removing it.
the seal itself is cheap but not the labor
oil and looks like a bit of coolant leaking soulcaliber39 4.6L V8 Technical Discussions 5 12-28-2016 05:57 AM
2012 3.7 V6 water pump.. what's the trick? eastexsteve 3.7L V6 Technical Discussions 1 12-04-2015 06:41 AM
19" Machined Rim plasti dip? Jwoolsey08 New Member Area 11 10-02-2015 09:42 AM
need a water pump step by step guide needhelpplease 2005-2014 Mustangs 7 09-04-2015 10:59 AM
Oil leak Itzjoe 5.0L (1979-1995) Mustang 11 08-26-2015 09:15 PM
02, 2002, 2002n, 2004, 9904, dorp, fluid, gt, leak, leaking, litle, manual, mustang, oil, tramision, transmission, v6
