What should it run?
Old 03-29-2011, 08:43 PM
ctgreddy
ctgreddy's Avatar
it's amazing how much a tune can help when you're comparing it to one that's pretty lackluster. my '95 had a crappy tune on it at one point, got 12.8's out of it. then i swapped my lca's and got a mail order and got 12.2's. dropped 6 tenths by some lca's and a mail order. if your mail order isn't performing good then I think a custom tune would net you 11's for sure like you're looking for. but how the heck did you run it so quick? lol. just 2 hours ago you were asking about the times and now you've already ran it. lol
ctgreddy is offline
Old 03-29-2011, 09:39 PM
99gstang
99gstang's Avatar
I was a little embarressed to post my time with all the mods, the actual weight of the car 3,055 lbs if the scale was accurate, tires & suspension, aluminum flywheel, ram clutch, stock trans & shifter, stock rear w/4:10 gears. I was hoping for a 11.90-12.00. When i had my 1990 5.0 it ran 11.90 with HCI 3000 lbs with driver with the factory stock ecm and no tune.
99gstang is offline
Old 03-30-2011, 08:50 AM
99gstang
99gstang's Avatar
Thumbs up
Thanks for your help
99gstang is offline
Old 03-30-2011, 08:51 AM
99gstang
99gstang's Avatar
Originally Posted by mrtstang
Actually that might make a big difference. Back when i was just bolt ons only (no cams, headers, or nitrous) and had a mail order tune, i put down 260 rwhp. Well when i did the nitrous i decided to get a custom dyno tune, and even though my n/a numbers were still the same 260 rwhp at the time., the car ran noticeably better. It was faster at WOT, had better throttle response, etc...
So my point is, in your case (having a full HCI setup) you should benefit from one far more than i did at the time with just bolt ons.
That's just my opinion.
Thanks i appreciate your input and help.
99gstang is offline
Old 04-17-2011, 04:07 PM
99gstang
99gstang's Avatar
Default Correction
Originally Posted by 99gstang
Well as much as i hate to admit it, i ran the car without a custom dyno tune, only a custom mail order tune, i was i little disapointed with a 12.119 @ 111.44 considering the weight of the car, tires & suspension and a 1.647 60 ft. i thought it would run 0.1-0.3 tenths quicker. I realize i should've waited to have it tuned on the dyno, hopefully its not too late. I was wondering if the tune is hurting the car, i doesn't run that well under 2500 rpm and i've had a couple of codes. Does anyone know if i can cut 0.1-0.3tenths off the 12.119 time with a custom duno tune?
Update 4/14/2011
Now I feel like sh!d, I installed the cams, than ran this car for 4 months, and made 5, 1/4 miles passes with the left cam installed 180* off. I took everything apart and reinstalled the cams.
Update 4/17/2011
Cams are installed correct now, the miss is gone. Seems like it runs much better. Will it make more hp/tq?
99gstang is offline
Old 04-17-2011, 06:49 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
+1 for a good tune.
so this is where you are now?! sold the 95 and crossed over to the dark side?
lol im picking up a 96 GT next week
sn95_331_GT_ yellow is offline
10-07-2015 07:02 PM
heslekrants
09-23-2015 04:02 PM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
MusicCity615
09-12-2015 07:05 AM
uedlose
09-10-2015 03:30 PM
Quick Reply: What should it run?
