crank trigger wheel - MustangForums.com
Old 04-21-2011, 08:55 PM   #1
harbre32
harbre32's Avatar
Default crank trigger wheel
hey guys, i read on different forums that our trigger wheels are junk and should be replaced with a billet one. First, do you agree? if so who makes a good one? thanks
harbre32 is offline   Reply With Quote
Old 04-21-2011, 09:32 PM   #2
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
I have never heard or experienced anyone who has had the crank trigger wheel fail. Do you mean crank dampener by chance?
WhiteFoxGT is offline   Reply With Quote
Old 04-21-2011, 10:23 PM   #3
BraMas
BraMas's Avatar
Seems a littles weird to me. The crank wheel is nothing more than a stamped wheel with teeth all around it with one tooth missing and that is how the crank sensor knows where the crank is in its rotation.
BraMas is offline   Reply With Quote
Old 04-21-2011, 11:06 PM   #4
cliffyk
TECH SAVANT
cliffyk's Avatar
That's about the silliest thing I've heard recently--on exactly which forums did you collect this pearl?
I'd like to know so I can blacklist them...
cliffyk is offline   Reply With Quote
Old 04-22-2011, 06:02 AM   #5
harbre32
harbre32's Avatar
modular mustang. also read it in several books. It does mention it on the MHS sight at the bottom of the adjustable crank gear article.
Old 04-22-2011, 06:32 AM   #6
uberstang1
Chupacabra
uberstang1's Avatar
Lmao fasle information, but these cars do have issues with muffler bearings.
uberstang1 is offline   Reply With Quote
Old 04-22-2011, 07:06 AM   #7
zero2005
zero2005's Avatar
lol, muffler bearings, never gets old. the only thing i've found that mensions anything about crank trigger wheels is that the older cast versions may be prone to cracking. if you already have the stamped wheel, there's no problem. i cant load the MHS page to find it, because my damn hotel internet aint workin.
edit: got it to load, here's what MHS says "The cast thick trigger wheel as used by Ford up to 1999 is junk IMHO, just get a stamped one."
if your in the middle of doing a cam swap or something where your in that area of the motor, then yea, it might be beneficial to swap out the crank trigger wheel for a stamped steel one, but if it aint broke, dont fix it.
zero2005 is offline   Reply With Quote
Old 04-22-2011, 07:54 AM   #8
harbre32
harbre32's Avatar
Im guessing that statement is referring to stangs from 99 and earlier. And yes im asking this question because im in the middle of a cam swap
Old 04-22-2011, 08:25 AM   #9
zero2005
zero2005's Avatar
yep. if you have the thicker one you can replace it, MHS has them. bit expensive if you ask me though, 35$ for a peice of stamped steel.
apparently it was "Stock on all 2001 and newer modulars." (MHS quote again) so if you have the thick one, and you dont feel like replacing it, i'd say you'd be fine. if it aint broke there's nothing to fix, unless you feel like dishin out the cash for one or trying to find one used. if you've used it this far without it braking, i'd say your good to go.
Old 04-23-2011, 05:25 PM   #10
tbirdscwd
tbirdscwd's Avatar
I'll put that on the top of my mod list next to billet PCV valve
tbirdscwd is offline   Reply With Quote
Dual Concave!! Manny92392 2010-current S197 Appearance Section 5 10-05-2015 12:39 PM
HELP! Dead Battery After Tire Change?!! jessicarabbit GT S197 General Discussion 12 09-25-2015 01:41 PM
All 10-14' Mustangs w/ Sync Raxiom Navigation Unit - Not Working - yourmom6990 Parts For Sale 2 09-14-2015 11:52 PM
Will not fire up Wombatnation 5.0L (1979-1995) Mustang 12 09-13-2015 10:16 PM
Annoying rattles in cabin - 2014 V6 tmdm 2005-2014 Mustangs 1 09-04-2015 07:45 PM
2000, 2004, 50, 95, 98, cobra, crank, crankshaft, gt, install, location, mustang, trigger, v6, wheel
