GM IAT Sensor - MustangForums.com
Old 05-22-2011, 10:15 PM   #1
MustangMan00
MustangMan00's Avatar
Default GM IAT Sensor
Hey guys,
I'm going with a screw in IAT sensor. I need to wire into my existing one. I found from research that there is no polarity on IAT's so it doesn't matter which wire is which. Is that correct?
Has anyone used one of the GM IAT's before? I read they are more responsive as well.
Thanks again
MustangMan00 is offline   Reply With Quote
Old 05-22-2011, 11:08 PM   #2
0949er
0949er's Avatar
howd you like my burnout
0949er is offline   Reply With Quote
Old 05-23-2011, 05:31 PM   #3
Chris98Gt
Chris98Gt's Avatar
I've not used a gm iat sensor, but this is what I'm using now with no issues. plugs into factory harness.
http://www.vmptuning.com/store/index...d=25&parent=27
Chris98Gt is offline   Reply With Quote
Old 05-23-2011, 06:21 PM   #4
97stanger
just a few weeks ago when I had to relocate my IAT for the meth setup, I went with a GM. Car ran like ****, I put a lightning IAT in and wa la
97stanger is offline   Reply With Quote
Snow performance stage 2 MAF boos cooler install jwog666 Pipes, Boost & Juice 5 04-04-2016 05:23 PM
Bad cylinder? Dathan V6 (1994-2004) Mustangs 4 10-05-2015 06:52 AM
Please help! 10 Check engine codes mrtrodonet V6 (1994-2004) Mustangs 1 09-29-2015 12:13 PM
O2 sensors Big Al's 03 Mach 1 Section 4 09-21-2015 08:59 AM
OBD: The Adventure Begins (PO402 and PO401), DPFE/EGR test procedures TfcCDR V6 (1994-2004) Mustangs 1 09-14-2015 01:08 PM
04, 1997, 2004, 98, car, ford, gm, gt, iat, mustang, polarity, range, screw, sensor, test
