PI Swap Parts?
Old 06-13-2011, 05:06 PM
zpstang96
zpstang96's Avatar
Default PI Swap Parts?
I've read many posts on what is needed for a PI swap on a 96-98 GT, but I've yet to narrow down what exactly it is I need. Figured I would post what I know I need and then see if there's anything missing.
Here's the list:
I have a 96 GT--the whole engine is stock besides a CAI and I drive the car daily.
For the PI swap here is what I have so far that I have deemed necessary:
PI Intake Manifold
PI heads w/ cams
Head changing kit from Late Model Restoration
I am planning on doing a Romeo to Romeo swap. I have also heard posts about new O rings?
It would be great to hear from anyone who has done the swap and knows what else I need.
During the swap I'm also going to throw on a 75mm TB/Plenum, long tubes and a shorty mid pipe.
If there are any other things I need to do this swap please let me know..I feel like I am missing some things and do not want to start the swap without knowing that I have everything.
Thanks
zpstang96 is offline
Old 06-13-2011, 05:36 PM
lizzyfan
Underboss
lizzyfan's Avatar
4.6L PI Cylinder Heads (complete)
PI Intake Manifold (with aluminum water crossover passage)
Intake Gaskets
Thermostat and O-Ring
Thermostat Housing Bolts
Heater Hose (for the different runner length of the PI Intake)
Heater Hose Nipple
Alternator Bracket and Bolts
Dipstick Tube
Camshaft Bolts
Head Gaskets
Exhaust Gaskets
Valve Cover Gaskets
Timing Cover Gaskets
Water Pump Gasket
OEM Ford Head Bolts
Motorcraft Spark Plugs
lizzyfan is offline
Old 06-13-2011, 05:39 PM
lizzyfan
Underboss
lizzyfan's Avatar
Also
https://mustangforums.com/forum/4040408-post4.html
lizzyfan is offline
Old 06-13-2011, 07:09 PM
zpstang96
zpstang96's Avatar
just what i needed, thanks
Old 06-13-2011, 09:36 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
Originally Posted by lizzyfan
haha ive been living on this thread ^^ for the last few weeks making sure everything i have is in order lol
sn95_331_GT_ yellow is offline
Old 06-18-2011, 08:40 PM
thestang98gt
thestang98gt's Avatar
Default PI swap
Just signed up, but I've been looking for someone who had parts listed too who has done the swap.
This thread looked recent and I know it's probably been talked about a lot, but I get the feeling I won't get a quick reply w/o chatting in a newer thread.
My question is, these are the direct replacements for the 99-04 2V stang GT's.
Will this kit contain everything I need head wise other than gaskets, head changing kit, and studs and bolts? I know it's not the fancy trick flows or anything, but it's all I can afford right now and just want to get the swap done and 99-04 intake installed.
http://www.latemodelrestoration.com/...-Cylinder-Head
http://www.americanmuscle.com/typhoo...-polished.html
The first 2 are the heads, and last is the intake. The intake though doesn't look like it has the spot to drill the hole for the second sensor you are talking about. is that because it has a spot already machined for it?
thestang98gt is offline
Old 06-18-2011, 09:54 PM
lizzyfan
Underboss
lizzyfan's Avatar
PI heads can be had for cheap
lizzyfan is offline
Old 06-19-2011, 05:57 AM
everett
everett's Avatar
Ok. So if anyone is doing this swap I have Windsor Pi heads with cams,plastic lower intake(no leaks),upper intake with choice of either a bbk cai or stocker with new k&n filter,fuel rail,stock injectors,COPS X6. I have everything needed to do swap other than timing cover,gaskets,new head bolts,and Windsor valve covers. One stop shop here. I am in Canada so shipping will be about 200 bucks. These parts are still on car. I am waiting til my ported and polished heads get here then I will be removing everything. I also have timing chains and guides if needed. Reasonable offer will take them. I expect my heads this week so this weekend I will be pulling these parts. Pm me if interested
everett is offline
Old 06-20-2011, 10:46 AM
98mustanggt28144
98mustanggt28144's Avatar
(subscribed to thread) when i did my pi swap i didnt change the nipple just the coolant tube (no leaks) i didnt replace any gaskets thermostat hoses or anything!! of course i changed heads gaskets,bolts and intake gaskets but my car runs fine and have had a few problems but my question is this i keep getting a lean code on both banks??? now was i suppose to switch over to cops too??
98mustanggt28144 is offline
Old 06-20-2011, 10:48 AM
98mustanggt28144
also i didnt change my dipstick tube but that head is the hardest little sob to put back on
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
97SN95GT
09-13-2015 09:45 PM
cbird1177711
09-03-2015 08:43 PM
Steve@CJPP
CJ Pony Parts
09-03-2015 11:43 AM
Quick Reply: PI Swap Parts?
