TOB/ Clutch arm issues
Old 06-26-2011, 11:20 AM
Bmitchell373
Bmitchell373's Avatar
Default TOB/ Clutch arm issues
I have less than 10k miles on new clutch, pressure plate, tob, supposedly new clutch arm. I had the car on the lift with the engine running and inspection cover off and the clutch arm is rattling bad. the tob looks to be spinning true. I have to put a good amount of arm on it to keep it from rattling. When in the car if i press the clutch 1" itll stop as well. Anyone experience this? all i can conclude is that the pivot ball is backing out? Any ideas?
Bmitchell373 is offline
Old 06-26-2011, 12:37 PM
98redstang
98redstang's Avatar
the retainers that hold the TOB in place could be bent or worn. What kind of clutch is it?
98redstang is offline
Old 06-26-2011, 12:39 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
How much free play is there in the pedal?
cliffyk is offline
Old 06-26-2011, 01:33 PM
Bmitchell373
Its a "oem" LUK clutch. about 1/2" the cable does need to be replaced.
Old 06-26-2011, 08:16 PM
98redstang
98redstang's Avatar
usually you replace it when you do the clutch depending on the miles. but still shouldnt be causing the chatter
Old 06-26-2011, 08:26 PM
Bmitchell373
Cause I know it needs to be done, I'm going to order HD adjustable cable, firewall adjuster and quadrant.
Old 06-26-2011, 08:34 PM
98redstang
98redstang's Avatar
get the adjuster and quadrant but the stock cable is actually better than most cables out there so i would get a stock replacement.
Old 06-26-2011, 08:37 PM
Bmitchell373
I was looking at the UPR HD one. A OEM Ford one would be better?
AmericanMuscle4.6GT
11-10-2015 02:06 PM
PNYXPRESS
09-14-2015 09:50 PM
MasterLanMan
09-13-2015 08:21 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: TOB/ Clutch arm issues
