chip in key?
I had a new key made at a Ford dealer years back...and IIRC it was about that price, give or take. It isn't as inexpensive as getting a house key made at a hardware store. The PATS chip in the key is why.
Any competent, well equipped locksmith can make and program a key--does not have to be a dealer. My '03 GT came to me with just one key and a local shop cut and programmed it for $30. That was 4-1/2 years ago though...
cliffy, correct me if im wrong, but isnt a programmed key just a key with a resistor on it that produces a specific resistance, showing the key is "correct"?
they dont use RFID do they?
Here there are really only a few good shops.
The transceiver in the PATS module (standalone in some PATS types, and in the PCM or instrument cluster on others) energizes the key's transponder through the "halo" surrounding the key slot.
The transponder sends a encoded message to the PATS module, then the module sends a signal to the PCM to enable/disable the fuel pump and injectors (and starter in some models).
OK, now for more than your ever wanted to know about PATS (SecuriLock™):
Of the seven PATS types Ford has made from 1996 through 2010 (A, B, C, D, E, F, and G), only three were used on Mustangs from '96 through '04; A, B, C.
Type A ('96 to '97) and type B ('98) use a standalone PATS module.
With type C ('99 to '04) the PATS module is integrated with the HEC (Hybrid Electronic Cluster; I.e. instrument cluster) and shares a unique security ID with the PCM that was programmed at the factory--so the HEC and PCM are "married". The car will not start if you swapping out either without also swapping its mate.
Type D was never used in Mustangs, it is all contained in the steering column lock module.
PATS type E (completely contained in the PCM, as is type F) was used from '05 to '09;
The 2010 models reverted to the type C type PATS--which IMHO, and apparently Ford's, is the most secure of them all.
Type G, also an instrument cluster/PCM system, is used in some '08 to '10 E-series vans, some '08 to '10 big F-series (> F-8500), and the '07 to '10 Ranger.
