Old 10-26-2015, 02:32 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Smells like Gas
Old 07-05-2011, 04:01 PM
Case's97GT
Case's97GT's Avatar
Default Smells like Gas
Okay i noticed this last year at the end of the summer too. When ever it gets really hot I can smell gas inside and outside the car. Today it was 101 degrees out and all I could smell was gas. Not burning rich kinda gas but like a gas leak kind. However, I have looked the engine over several times and there are no leaks and there is never even so much as a drop of gas on the floor. It doesn't seem to be coming from the gas cap or the tank, because when you get right next to it you can't really smell it. I have a 97' GT. Does anyone know why this might be happening? I know the car runs a little rich.
Case's97GT is offline
Old 07-05-2011, 07:20 PM
huey_33
huey_33's Avatar
Subscribed!! Something familiar is happening to my car. Doesn't matter if its hot or cold, whenever I drive the car I get a smell of gas coming from the rear of the car. I have check the fuel tank and everything around it and I can't see any gas dripping. Need to know whats going on before I catch on fire.
huey_33 is offline
Old 07-05-2011, 08:28 PM
Case's97GT
Case's97GT's Avatar
Well my smell I can't pin point where the smell is coming from, but I know that It's not coming from the rear of the car.
Old 07-08-2011, 01:12 PM
Justin00GT
Justin00GT's Avatar
Same problem when I just filled my car up (2000 GT I just bought from orig owner last week). I had been filling it up to 1/2-3/4 but topped it off a few days ago and when the wind changes direction and blows from behind, I get a strong gas smell.
No leaks I can tell, just a stupid locking gas cap I want to replace with an original. As I think it might be the culprit.
Justin00GT is offline
Old 07-08-2011, 03:44 PM
Blackvenom01
Blackvenom01's Avatar
well your tanks are vented and in the extreme changes of temp it can cause it put off more fumes thus having a gas smell...if its all the time then it sounds like a possible leak
Blackvenom01 is offline
Old 07-09-2011, 09:19 AM
PROMETHEUS PRIME
PROMETHEUS PRIME's Avatar
I would check the gas tank really well were the filler neck goes into the tank. There is a groumet there that many times fails on the top part and may only leak when topping off the tank. Not always leaking on the floor but you may be able to see residue or stains right under it. I've changed tons of these for that problem
PROMETHEUS PRIME is offline
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
Sixer4Life
10-12-2015 04:26 AM
b8checker
10-08-2015 12:55 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: Smells like Gas
