I have the run of the mill vortech setup. V1 8lb pulley 255lph fuel pump 39lb injectors. I replaced the stock maf with a 95mm maf sensor and removed the vortech chip. The new 95mm maf is calibrated to the 39lb injectors. I also installed a Anderson power pipe. The car will not stay running now. The car only starts up for a few seconds and shuts off. Any guidance would be appreciated. The vehicle ran just fine prior to the mods.
Maybe I'm wrong here but when running FI on 94 and newer I believe some sort of tune is required. The Vortech Chip had the tune in it. Improper tune the car will shut down.
im sure you will have to get it tuned , i dont belive you can just change the maf. there are a few threads i have read about this . which maf did you get?
your going to have to put the vortech chip in and get a tune,your getting alot more air in with the pipe and its prob gonna be lean if you do get it started on stock,could also be a vacume leak but you need to tune it for more air coming in
