Changing Spark Plugs
I've got a 1999 GT 4.6L 5 Speed.
I'm about to undertake changing the spark plugs for the first time. I am NOT a mechanic, but I follow instructions. Unfortunately, the picture in my Chilton manual is of a dual overhead cam engine and looks nothing like mine.
Is there a procedure available (hopefully with pictures) that will help me do this right and not remove the fuel injectors by mistake?
Thank you,
Thank you,
I know how people feel about posting hear-say, but, I've HEARD that changing plugs with the engine hot, or even warm, just about multiplies the chance of the plug taking the threads in the head with it. I believe I heard that here in fact, I just choose the safe route and do it first thing in the morning after the car has sat all night.
Just my .02, and, if I'm wrong on this someone please do correct me.
There is no such caution in the shop manual, and there would be if Ford's engineers felt it needed--however it is good practice to not change them on either an extremely hot or extremely cold engine. There is a TSB for the '05+ 4.6L that says to change them with the engine at "room temperature, however I could not find any such bulletin for the earlier engines.
I have swapped plugs (and COPs) literally 2 and 3 times a day while doing field trials for an aftermarket manufacturer with no ill effect, in each instance I let the engine cool to "warm" (140°F or so) before swapping the plugs.
I DO use a torque wrench to tighten them each and every time, and would not recommend that anyone not do so; especially a "newbie". HF has a nice 1/4" drive clicker that is often on sale.
While you are there pick up this extra deep spark plug socket, it greatly minimizes the possibility of the socket getting cocked on the plug--which can also create problems--and lines things up very well when installing the new plugs...
As to plugs I can only offer my position--I run Champion plugs in most every vehicle we own or have owned, stk# 3401 single platinums¹ in my '03 GT.
Champion has been making spark plugs for over 100 years, if there were some better way to make them they would have figured it out a long time ago...
¹ - Actually I have the same plug in a double platinum flavour (stk# 7963) in there right now as I was testing some aftermarket COPs that fired with a reverse polarity.
