school me on "3rd gear wall"
Old 08-02-2011, 05:33 AM
Blackvenom01
Blackvenom01's Avatar
wow i did not know all this for just the fluid...my tranny leaks outta the output shaft and slings up on the under carriage i pulled out the fill plug and alittle poured out and let it sit...ended up slowing down the leak i wonder if i should drain it and redo it...it only crunches into 4th when it really cold outside like around 40F so once its warmed its good hmmm...good knowledge cliff!!
Blackvenom01 is offline
Old 08-02-2011, 05:54 AM
FlamingoGT
FlamingoGT's Avatar
Does the Cobra have the TR3650 tranny?
But that question aside, in any tranny that I have had, if fluid comes out the fill hole then it is definitely overfilled. In the case of the Mustang 3650 (and probably any other 3650) the proper fluid level is below the bottom of the fill hole (I think I read somewhere about 1/4"... of this I'm not sure as I just go by qty put in)
FlamingoGT is offline
Old 08-02-2011, 06:57 AM
craigjschr
craigjschr's Avatar
does the T45 use the same amount of oil
craigjschr is offline
Old 08-02-2011, 07:02 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
You can download an owner's manual here...
cliffyk is offline
Old 08-02-2011, 07:17 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Assuming you mean the '03/'04 Cobras, no. They used the Tremec T-56 6-speed tranny.
3/4" per the TSB...
I have "checked" this using a cable tie with a 1-1/4" 90° leg bent into it--use it through the fill hole like a dipstick...
cliffyk is offline
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: school me on "3rd gear wall"
