school me on "3rd gear wall"
Old 08-01-2011, 04:06 PM
rafacalz
rafacalz's Avatar
Default school me on "3rd gear wall"
I'm having problems shifting into 3rd gear at high rpms. Did some reading around, but really couldnt find a way to solve the problem.
My car is an 04 GT
thanks
rafacalz is offline
Old 08-01-2011, 05:06 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Have you changed the transmission fluid, and used only 3.2 qts on the refill? This TSB explains more about this. If you have never changed it then it is overfilled, if it was changed by a dealer it may still be overfilled, if it was changed by a "quikee" lube place then it may be grossly overfilled.
BTW and FWIW, I had run RP Synchromax for 50k miles or so but found that Mobil 1 ATF performs better in my '03...
cliffyk is offline
Old 08-01-2011, 05:09 PM
dominant1
dominant1's Avatar
yes check that fluid level, if you change it use a synthetic fluid. Also consider an aftermarket short throw shifter, you never miss 3rd with them....
dominant1 is offline
Old 08-01-2011, 05:34 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
To clarify, you cannot really "check it" as the proper level is well below the filler hole (which is why "quikee" lube may have grossly overfilled it)--just drain and refill with the proper amount. Remove the filler plug first, only once in my life have I drained a tranny and then found the filler plug would not come out, but that was all it took.
As to an aftermarket shifter, most of the regulars here know my preference:
cliffyk is offline
Old 08-01-2011, 06:17 PM
fordforlife0225
fordforlife0225's Avatar
MGW?
i have a pro 5.0 and i love mine, very easy to find third and very clean shifter.
fordforlife0225 is offline
Old 08-01-2011, 07:22 PM
rafacalz
rafacalz's Avatar
sweet!!! thanks for the fast responses. The MGW was actually the short throw i was looking at, I've read a lot of good things about them. Guess that will be the next thing I'll be getting for my car.
rafacalz is offline
Old 08-01-2011, 08:59 PM
craigjschr
craigjschr's Avatar
so i should use mobil one ATF on my 2000 mustang gt 5 speed.
craigjschr is offline
Old 08-01-2011, 09:28 PM
trailor
trailor's Avatar
not necessarily. a 2000 gt doesnt have the t3650 transmission, so its fill specs and recommended fluid could be quite different. looks up some specs for t-45 trannys.
trailor is offline
Old 08-01-2011, 09:44 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Your 2000 has a Tremec T45 transmission; the original specification was for Mercon ATF, a conventional oil no longer available. Mobil 1 ATF is a suitable alternative.
As to whether you "should" use it, that's your call. Any Dexron/Mercon III or better rated fluid will work...
cliffyk is offline
Old 08-02-2011, 05:32 AM
uberstang1
Chupacabra
uberstang1's Avatar
I get get performance from royal purple ATF in my t45, have a stash of royal purple synchromax which is going in soon.
uberstang1 is offline
Quick Reply: school me on "3rd gear wall"
