Sputtering at start-up...
Old 10-04-2011, 12:57 AM
myk
myk's Avatar
Originally Posted by MidNightRunner
Keep in mind that it might be a hose leak, not the manifold, causing the pooling giving you the sputtering problem.
I replaced the hoses a few months ago-I'm pretty sure it's the t-stat housing or some other part of the manifold.
So, if a plug or injector is now fouled by coolant do I just clean both as best as I can? Would I have to worry about coolant in the cylinder? What would be the proper way to try and start the car up again?
I'm really hoping it's just a loose plug...
myk is offline
Old 10-04-2011, 09:00 PM
myk
myk's Avatar
And here's to hope realized-the #8, or farthest back plug on the passenger side was flopping around inside of its chamber. That plug is a real b**ch to deal with, what with that fuel rail shield in the way. Any suggestions on how to better deal with that? I'm guessing it comes off but it's dark and the car's running again so I'm done for the day...
myk is offline
Old 10-04-2011, 09:24 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
That's #4, #8 is at the rear of the driver's side...
If you are referring to installing an threaded insert it is indeed a PITA to get at--it's best to pull the fuel rails and intake manifold if you are trying to install an insert...
cliffyk is offline
Old 10-05-2011, 01:23 AM
myk
myk's Avatar
No I wasn't referring to a threaded insert, just wondering what some people did to make dealing with plug #4 easier. I've read that some people remove that bracket/shield thing attached to the fuel rail, for example. I'm going to have to go back in there and test the tightness of that plug-I'm sure I snugged it but I don't EVER want to deal with this again...
myk is offline
Old 10-05-2011, 08:25 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
I use an extended plug socket, and whatever length wobble extension happens to fit (6" IIRC).
Haven't found it being any but perhaps a bit awkward--I've seen a lot worse.
cliffyk is offline
Old 10-05-2011, 04:11 PM
myk
myk's Avatar
True. The plugs & wires on my '97 LT1 were a complete nightmare...
myk is offline
ShaneB26154
35
03-04-2021 04:05 AM
MEISTERSNFB
03-31-2020 07:50 AM
mustang96gt
03-21-2006 08:10 PM
SGTMack
02-07-2006 04:40 PM
tokinGLX
01-08-2006 11:50 PM
Quick Reply: Sputtering at start-up...
