Gear whine?
Old 08-16-2012, 03:56 PM
Seabee1993
Seabee1993's Avatar
Default Gear whine?
I've got a 2000 GT, w/manual. Still getting used to the sounds of the car, but I'm detecting gear whine when I drive 4th and 5th gear, now I was used to it in my old mans old 51 pickup but never expected it in a more modern vehicle.
Some thing I should be concerned about? Thanks!
Seabee1993 is offline
Old 08-16-2012, 04:37 PM
BraMas
BraMas's Avatar
Do you know.if it has aftermarket gears? Also i have noticed alot of noise coming from the shifter area if an aftermarket shifter is installed and they did not put a gasket on the base
BraMas is offline
Old 08-16-2012, 05:24 PM
Seabee1993
Seabee1993's Avatar
No, not from the the front of the driveline, from the rear end. Sounds just like my dad's old truck! LOL (His had granny gears though)
No idea, bought this from another older guy abou two weeks ago. He did tell me he just changed the lube out on the rear and the plugs before we parted ways. Stock is 3.27 right? That's what I found for specs. I mean the car is solid, just a whine when I'm going faster than 50. It's not annoying, it's just there. It just sounds like an old truck! LOL
Old 08-16-2012, 07:37 PM
chickensofttaco
chickensofttaco's Avatar
sounds like he changed the fluid for that reason.. if gears arent adjusted properly it will whine and probably damage the gears. are you sure its stock gears? maybe he "slapped" the stockers in to sell it? my rear end sure dont whine and i got 140k..
chickensofttaco is offline
Old 08-16-2012, 08:08 PM
Seabee1993
Seabee1993's Avatar
I have no idea what this guy did, it's my problem now. Guess I'll have to figure it out... Any of you in MS know rear ends? LOL
Old 08-17-2012, 08:28 AM
BraMas
BraMas's Avatar
Change the fluid again maybe he forgot to add the friction modifier
BraMas is offline
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Gear whine?
