Clutch release bearing question. - MustangForums.com
Old 10-17-2011, 07:26 PM   #1
95SHO
Default Clutch release bearing question.
I have a 2001 GT and I am installing a new clutch after only a few thousand miles. Ever since I installed it a few months ago the throwout bearing has been making a noise when the clutch wasn't pushed in. I tried a firewall adjuster but it didn't help. The clutch grabbed perfectly maybe a little high but I was happy with it except the noise. So I ordered a new Exedy clutch, new Ford clutch fork, new Ford Racing Throwout bearing and Ford Racing pilot bearing and a new Ford clutch cable. My question is why do these throwout bearings have a bump on them where they slide into the clutch fork? Does it have to be facing a certain way? Probably a stupid question but I don't want a premature failure again. I can take a pic if it helps.
95SHO is offline   Reply With Quote
Old 10-18-2011, 09:50 AM   #2
cliffyk
TECH SAVANT
cliffyk's Avatar
It is to keep the back end of the TOB from rotating in the release lever--doesn't matter how it is inserted into the lever, it will just turn "so far" first time it turns at all...
cliffyk is offline   Reply With Quote
Old 10-18-2011, 10:52 AM   #3
95SHO
Quote:
Thanks man, I just wanted to make sure it didn't need to be in there a certain way.
Chirp during hard shifts? 6bangr 4.6L V8 Technical Discussions 5 02-15-2016 07:40 AM
Possible Clutch Issues..? Thunderball 4.6L (1996-2004 Modular) Mustang 15 11-22-2015 11:49 PM
What other parts should I be concerned about if my pinion bearing went bad? KingRando 2005-2014 Mustangs 5 10-02-2015 08:06 AM
Centerforce Clutch, will a exedy flywheel work? junior04 4.6L (1996-2004 Modular) Mustang 1 09-28-2015 10:53 AM
91 vert tailpipe smoking MacSerio 5.0L (1979-1995) Mustang 3 09-27-2015 01:05 PM
bearing, bearings, bump, clutch, ford, in, lump, matter, mustang, racing, release, rotation, throwout
