new motor - when should first oil change be
everyone is going to have their own opinion/strategy. I really dont think it matters all that much when you put synthetic in after a few hundre miles honestly, especially if you are running a blower. The rings seat almost instantly with boost.
instructions from my MMR sheet said after first 500 do the first oil change.
once i get my car streetable again and i can put some miles on the thing, i plan on doin dyno oil every thousand (dino oil) until 3-5k then swappin to the Purple... doubt the dino oil is really needed, just figure its 1 less thing for them to try and blame should i have any warranty problems... not that i expect to...
dino oil is WAY cheaper lol. when i first put the oil in my car it was like less than 10$ for 2 gallons...
I have broke in more then a few motors. I always change out the oil at 200 and again at 500. Then go to normal OCIs. I always drain into a clean drain pan and look at it too. You would be surprised what's in it.
As often as you care to do it, can't be changed too much on a new engine--I like BLKSTANGER's plan except I'd add a change at 1000, then 2000, and then every 2500-3000 as long as you own it.
My grandfather told me 45 years ago, "Oil is cheaper than engines"...
