How much would you pay?
your stock MAF is 80mm, your TB and plenum are 75mm. think about it.
also, with a 75mm tb/plenum setup, you are well enough beyond the max amount of usable airflow (cfm's) that your stock heads can withstand (source: www.paladinmicro.com, check the "Accufab Flow Data" section under the TB/MAF/Plenum tab on the side menu). at this point, without porting or installing stage x heads, you have nothing to gain with more airflow, and possibly could hurt your performance.
Dan04COBRA
09-30-2015 11:46 AM
