2000 GT Instrument Cluster swap
Old 11-03-2011, 05:55 AM
nikstang
nikstang's Avatar
Default 2000 GT Instrument Cluster swap
I have a 2000 GT cluster and want to upgrade my 94 with it. I need the wiring diagrams for the both of them. I figure it should be pretty strait forward from there.
nikstang is offline
Old 11-03-2011, 04:59 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
It won't be an easy swap as you will need to upgrade the PCM from EEC-IV to EEC-V to drive the speedometer, tachometer, coolant temp, MIL, and a few other warning lights.
Here is the 1994 cluster wiring diagram:
Note that only the MIL, the auto-tranny O/D lamps and the tach are controlled by the PCM--and all directly controlled at that.
Here is the 2000 cluster wiring diagram.
On the 2000 the speedometer, tach, ECT, MIL, O/D indicator and other function are provided as digital data over the Multiplex Communication Network. In later models this became called thethe SCP (Standard Corporate Protocol) bus--and is in fact the OBD2 data bus.
A microprocessor in the cluster reads the digital data and then drives the gauges, all of which are just identical servo motors; not "real" gauges at all. Here's a shot of the backside of an '01 cluster with the electronics removed.
cliffyk is offline
Old 11-03-2011, 05:14 PM
Sxynerd
Sxynerd's Avatar
You said that so gentle; like you didn't know it was going to ruin his day, lol.
Sxynerd is offline
Old 11-03-2011, 05:35 PM
nikstang
nikstang's Avatar
Not a bad thing at all just something else to make me find a 1995 Bronco or F-150 with a 302 to grab its wiring harnesses and PCM. They are EEC-V and OBD-II and that should do the trick.
nikstang is offline
Old 01-11-2014, 07:51 PM
curtisss
curtisss's Avatar
Default shorting out
WHAT can cause a cluster to stop working after 10 or 15 miles ?? Loss of ground ? How do you track that down ?
Seems to just be the fuel, tack and speed guages shorting out.
curtisss is offline
Old 08-07-2017, 01:48 PM
Clark0417
Clark0417's Avatar
any chance someone could help me out with the wiring diagram of the 2008 mustang instrument cluster or guide me in the right direction on installing new digital speedometer and tachometer??? ive been looking for days and found this forum in hopes of a solution or some kinda help.....ive googled and came up with nothing time after time grrrrr HELLPPP PLEASE
Clark0417 is offline
Old 08-08-2017, 10:28 AM
Z28KLR
Z28KLR's Avatar
Maybe, hopefully.... I suggest though that you re-post over in the "other" 4.6 section (relevant to 2005-10 model years). Highly unlikely anybody in this section will have much knowledge on this.
Z28KLR is offline
Old 08-08-2017, 02:08 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
if you are swapping clusters, whether new or used, it will need to be programmed. Using a ford IDS or similar you will have to suck out info from old one, install new one and download info on to it. Its not plug and play
WhiteFoxGT is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: 2000 GT Instrument Cluster swap
