Rear Diff Swap Possible with no issues?
Old 11-14-2011, 10:27 AM
Repzard
Repzard's Avatar
Default Rear Diff Swap Possible with no issues?
I cant remember when I replaced a wheel stud in rear if my Cobra had ABS rings?
Does anyone know if in fact this year had ABS?
Reason im asking and maybe someone can tell if the swap would work.?
I have a 1999 Mustang GT that has 4:10 gears in it
I have a 1997 Cobra that has stock 3:27
Id like to swap axles 99 to 97 and 97 to 99.
I know the axle in the 99 is a tad longer that the 97 but that would be good for the Cobra where the stock wheels tuck in but I have new wheels 10.5
can this swap be done with no issues for either Mustang ?
Now I know the 97 axle in the 99 will tuck the wheels in alittle but nothing a spacer or different offset wheel wouldnt fix.
Reason I asked about ABS rings as well is I think that would be the only issue if the 97 axle didnt have them.But I think it did.
Thank You Mfers for help
Repzard is offline
Old 11-14-2011, 11:45 AM
Repzard
Repzard's Avatar
NO ONE
Also put this in the SVT side and no one knew.
Someone must have done this swap in the past ?
Repzard is offline
Old 11-14-2011, 01:05 PM
ShadowDrake
ShadowDrake's Avatar
While I haven't done the swap I'm fairly sure all the cobras came with ABS, so that shouldn't be an issue. You can always pop under there and take a look. If the car has ABS, it'll have it on the rear. Check the engine bay for an ABS module, if that's easier.
Otherwise the swap should be direct and shouldn't take long as long as the control arm bolts come out easily.
ShadowDrake is offline
Old 11-14-2011, 04:38 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
How about you swap the housings and then keep the axles with the specific car.....OR go pull the wheel off your car and look yourself? Physically there is no reason why you can't switch the rears out.
Even quicker....go pop the hoods on the cars and see if they both have an ABS block....abs block means abs rings...
projectresto83 is offline
Old 11-14-2011, 07:57 PM
projectresto83
M.A.D. Motorsports
Originally Posted by uberstang1
Regardless wether or not it has ABS the swap will work just fine, the only thing is if one has ABS and the other doesn't the car that originally had the ABS will trip the ABS light.
Again, just a simple swap of the axles themselves...
uberstang1
Chupacabra
uberstang1's Avatar
uberstang1 is offline
Old 11-14-2011, 10:27 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
the new edge has a rear thats about 1.5" wider and IIRC the new edges use 12mm bolts vs 14mm for 79-98
they should both have exciter rings for the ABS
sn95_331_GT_ yellow is offline
Old 11-15-2011, 05:15 PM
Repzard
Repzard's Avatar
Thank You Mfers.
So the swap should go well.
Just need to get 3\4 - 1" spacers for the GT when the 97 axle assy is in it.
That will bring wheels to stock location as if the stock axle assy was in it.
Well I plan on doing this swap 1st thing in the spring and will post pics
I bet the 97 will love the 4:10
As for the GT its becoming my good weather DD so 3:27 will be better for my Highway driving.
Thanks again
Repzard is offline
Old 11-18-2011, 05:18 PM
Dave19525
Dave19525's Avatar
From what I have read the sn95 does not have the ABS ring which means your light will be on in the GT. I would just pull the axels and keep them with the original car and swap everything else. Its an easy swap. I had 4.10s in my GT and when I totaled it I swapped in an sn95 sixxer rearend from a junk yard. I am currently swapping that rearend into my Mach. 4v with 4.10 will be awesome, you'll love it.
Dave19525 is offline
Old 11-19-2011, 12:42 AM
sn95_331_GT_ yellow
wrong... ones on BOTH of my SN95's...
drfister
05-03-2018 10:38 PM
adamfrosceno
08-27-2015 07:40 AM
ding56
08-14-2015 02:40 AM
92 5.0stang
08-13-2015 06:46 AM
PearlGenPu
08-12-2015 01:57 PM
Quick Reply: Rear Diff Swap Possible with no issues?
