Alarm goes off after opening door?
I've been having an annoying problem the last few days with my car. I'll unlock the car with the fob but the second I open the drivers side door the alarm will go off. It only happens a third of the time though. I can't turn it off with the fob and the only way I can disable it is to disconnect the battery for a few seconds with the key in the ignition and the door open. It's left me frustrated and I would appreciate any way to entirely disable the alarm (fuse or anything?).
Look for a bypass button behind the hood release. I have read that you can ground both the wires going to the button to disable the alarm but I have not yet tried it. I just got my alarm problems fixed. I had some loose connections.
I just disables the horn for the alarm. I only recently invested a ton of money doing a tune up, detailing, clutch replacement and transmission repair. Not sure if I can afford going to a Ford dealership for a repair currently. Still I have no clue as to how much it could cost.
There was no factory alarm system for any '96 through '04 Mustang, however there was a Ford branded dealer installed alarm made by Code Alarm, which was later sucked up by AudioVox. I believe they still offer some support for the Ford branded systems.
They were not extra high-quality, but were not horrible either--AFAIK they were dropped when SecuriLock (PATS) finally got certified by the insurance underwriters.
Just wanted to post an update. Apparently I have to press the unlock button twice before opening the door. Haven't had my alarm go off once since I've started doing this. I'm feeling pretty dmb right about now
09-25-2015 06:58 PM
