leaking oil like a sive, whats this part called.
Old 12-10-2011, 12:57 PM
StockD15b
StockD15b's Avatar
Default leaking oil like a sive, whats this part called.
so the car is dumping oil like crazy when running. Where the oil filter mounts, whats that piece called?
I assume theres a gasket behind it because it looks like it bolts to the block. Thanks.
StockD15b is offline
Old 12-10-2011, 04:44 PM
uberstang1
Chupacabra
uberstang1's Avatar
Usually refered to as the oil cooler or oil filter housing. It uses an o-ring type seal
uberstang1 is offline
Old 12-10-2011, 04:49 PM
JC316
JC316's Avatar
Oil filter adapter plate gasket.
JC316 is offline
Old 12-10-2011, 05:31 PM
StockD15b
StockD15b's Avatar
would this be the part by chance?
http://www.autozone.com/autozone/par...72199_0_11573_
Old 12-12-2011, 01:36 PM
02WhiteGTVert
02WhiteGTVert's Avatar
it is the adapter plate. I broke one on my ex wife's 96 GT when i put a new motor in her car. They're somewhat fragile..it cracked while I was installing the oil pressure sending unit!
02WhiteGTVert is offline
Old 12-12-2011, 01:37 PM
02WhiteGTVert
You need to determine it's the gasket and not the housing itself...but yes that looks like the correct gasket. Make sure you don't torque on it too hard while reinstalling
Old 12-12-2011, 05:31 PM
StockD15b
StockD15b's Avatar
thanks bud.
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
Granatelli Sales
01-20-2020 12:34 AM
97SN95GT
09-13-2015 09:45 PM
09-02-2015 08:40 PM
Quick Reply: leaking oil like a sive, whats this part called.
