po171 freeze frame data info?
i have a po171 and po153 code. the scanner im using says the po171 code lit up the check engine light its a bone stock 98 gt.
po171:
RPM:2850
LOAD VALUE:89.4%
COOLANT TEMP:185'F
56 MPH
short term fuel-trim 1: 10.1%
long term fuel-trim 1: 25%
short term fuel-trim 2: 11.7%
long term fuel-trim 2: 25%
short term fuel-trim 3: 60.9%
long term fuel-trim 3: -44.0%
long term fuel-trim 4: -39.5%
short term fuel-trim 4: 97.6%
If anyone can point me in the right direction to fix this problem i would be extremly grateful
...also my car doesnt have any trouble idleing, accelerating or starting up? thank you.
po171:
RPM:2850
LOAD VALUE:89.4%
COOLANT TEMP:185'F
56 MPH
P0171 is a lean code bank 1 I believe off the top of my head.
Make sure you do not have any air leaks after MAF.(Intake area before TB)
Also could be caused by a dirty MAF as another option.Can try cleaning it and reseting codes.
P0153 is Oxygen sensor related..Could be failing?Maybe setting both codes?
My guess is its in bank 1 side of engine causing issue
ive replace the o2 sensors that are after the cat. weird thing is the ones that were on there originally werent the same? one was skinny and had ford on it the other was fat and had no brand on it? i got the new ones at rockauto "ultrapower" was the brand. it said OE style. so i guess im goona replace the ones after the cat next? also when i ran a monitor test all my systems worked fine excpet it said "evap system inc"?
I am confused by you statements, your said "ive replace the o2 sensors that are after the cat." and then "so i guess im goona replace the ones after the cat next?" So what is it that you have already replaced?
As the codes indicate both banks I would concentrate on things that affect each bank separately. Exhaust leaks before or near the front O2 sensors could cause both codes--lean on bank 1 and slow response on bank 2...
BTW, DTCs are always one letter and four numbers--P0171, not Po171...
Sorry lol I mean I replaced the ones after the cat. So i guess I'll change the ones before the cat next? Also I put the car up and I can't see any exhaust leaks. Would there be a noise if it was leaking from the header gasket?
Before changing the sensors make sure there are no exhaust leaks. You can bench test the sensors with a multimeter and propane torch...
Thanks alot I appreciate all the help. But I'm fairly sure there's no exhaust leaks? And let's just say the sensors are ok. What else could be the culprit? I've sprayed the intake and intake manifold and most of the engine with starting fluid and the car idled perfect. So that might rule out vacuum leaks?
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
junior04
09-28-2015 10:53 AM
mrappe
09-26-2015 10:16 AM
