Grease fittings.
Old 12-24-2011, 04:34 PM
SXGT
SXGT's Avatar
Default Grease fittings.
Does not look like i have any except for one sticking out of the brake caliper. IDK what that goes to. Isnt the sn95 sealed off? so I dont have to grease anything? also whats up with the fitting on the brake caliper?
SXGT is offline
Old 12-24-2011, 05:48 PM
BraMas
BraMas's Avatar
there should be no grease fitting on the caliper. Are you assuming the caliper bleeder screw is a grease fitting?
BraMas is offline
Old 12-24-2011, 06:14 PM
SXGT
SXGT's Avatar
Red face
Thats what I thought it was. just checking.
SXGT is offline
Old 12-25-2011, 12:49 AM
stevednmc
stevednmc's Avatar
Good thing you didnt just stick a grease gun on there! Ive seen the results, and it isnt pretty....
stevednmc is offline
Old 12-25-2011, 06:16 AM
uberstang1
Chupacabra
uberstang1's Avatar
Ummm it woudnt of done anything since the bleeder is closed.
uberstang1 is offline
Old 12-25-2011, 11:16 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Party pooper...
cliffyk is offline
Old 12-25-2011, 11:48 AM
stevednmc
stevednmc's Avatar
Ummmmmm....yeah, it did...the guy opened them. He turned them out and stuck the grease gun on there.....He went to special lengths of idiocy...It was a hell of a mess when he got done....!
Old 12-25-2011, 11:55 AM
FlamingoGT
FlamingoGT's Avatar
Even if the screw was closed, it would have still made a mess as the grease comes squirting out over everything else... just not a fatal mistake as it would only be a cosmetic mess.
Now I am going to step out on a limb... What about aftermarket parts such as ball joints, could they not have zerks (or however that is spelled... grease fittings)?
FlamingoGT is offline
Old 12-25-2011, 12:16 PM
stevednmc
stevednmc's Avatar
Certainly, after market ball joints or anything for that matter can have grease fittings. Personally i look for parts that do, I always consider that a bonus if it comes with them, or provisions for them.
Old 12-25-2011, 12:20 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
They could of course have Zerk fittings, some do, however because of significant improvements in synthetic "rubbers" modern boots and seals last much longer and are much better fitted than they were 25 years ago when grease fittings started disappearing.
If, for instance a modern ball joint, with the boot clamped top and bottom:
were to have a grease fitting all that would be accomplished with a grease gun would be to blow the boot (or it's clamps) apart--hardly the desired outcome...
Note: A high quality female Zerk coupling would not squirt grease all over if connected to a blocked fitting or brake bleeder. I've had hoses blow on pneumatic guns before the coupling leaked.
cliffyk is offline
Quick Reply: Grease fittings.
