How f**ked is my car? ( video )
12-25-2011, 10:52 PM
Quote:
Originally Posted by
Mike Hadz
i'm such a noob, but how do you do a 4v swap/how much would it run me/power gains? =}!!!
JC316 has a write up right in his sig.
Click on his link in sig, That will give you a idea what it involves.
12-25-2011, 11:03 PM
Good luck man. How many miles do you have on the motor?
12-25-2011, 11:14 PM
mineralpony
the motor has about 98k on it, it's fairly young, is it wrong for me to expect it to go near 200k with good maintenance?
12-25-2011, 11:21 PM
Mike Hadz
Ford 4.6 Liters can hit 300k if in good hands.
12-25-2011, 11:24 PM
oh 4v swap = swapping the whole engine?, not just heads etc?
12-26-2011, 12:22 AM
still looking forward to your ideas as to what's wrong with my engine, thnx
12-26-2011, 04:07 AM
any CEL codes? possible misfire with COP or along those lines? could be a # of different things
12-26-2011, 04:38 PM
bronxbomerss2
haven't checked for any codes or anything
12-26-2011, 04:43 PM
Drain the oil, if it looks like a milkshake, you've got water in your oil.. and its a head gasket. Don't drive it the way it is.. your gonna need some work done.. and the way its missing and blowing white smoke, water in your combustion chambers will make it so it wont ignite/combust, and if your head gasket is blown, more than likely its not blown for all 8 cylinders, therefore its causing your shaking problem..
12-26-2011, 06:21 PM
Mike Hadz
Check out his sig.
