Yes, his numbers are VERY good for his set-up.
Without cams I would have guessed he would make around 360 on 8lbs boost.
He should be real happy with those numbers.
Yeah i would of guessed the same numbers trueblue. I curius what it will do with cams
So it is a parasitic loss issue.
A p1sc requires a lot more power rotate it and generate 8# of boost than a d1sc does, so the net gain is a lot lower. Is that correct?
