Oil pump
Oil pump
Hi my name is Fernando, my dad and i just rebuild a mustang gt 4.6 engine but i am having this problem. when rebuilding we cheked clearences and we were between .015 to .020 with main and rods even installed a? mechanical gauge, when i fired it up the presion started on 50 psi and with a rattling noise at idle, presion was ok but when the engine got hotter presion droped to almost 20 to 15 psi and oil volume was ok. should i change the oil pump or check compression????
this is normal. my buddies engine which has a brand new ford oil pump has pressure around 50-60psi when cold and drops down to about 15 once the oil's warmed up. it's just because of how thin oil gets when it's hot. as long as you have roughly 10psi of oil pressure for every 1000 rpm then you're fine. so if you've got 10psi at idle you're good to go.
That's why Ford put in a "dumby" oil pressure gauge. People would always think something is wrong as the oil pressure fluctuates much more than people think.
My oil pressure when cold is 80-85psi and when warm at idle it's around 15-20psi. Other than the rattling you describe the oil pressure seems normal.
the good thing than is that i have good oil pressure than i was scared since i thoughtj that was a minimum measure and maybe blow the engine... again!!! JK. ill check the cover and keep u guys posted, hope this problem gets solved as soon as posible
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
