clutch problem.
Old 02-03-2012, 04:14 PM
EddyG
EddyG's Avatar
Default clutch problem.
ok so i got a manual mustang a couple of days ago. all black 98 GT. so i realized that the clutch grabs near the top. not right at the end but very close to it. how do i make it grab lower? its a stage 2 clutch and no aftermarket adjusters.
EddyG is offline
Old 02-03-2012, 06:29 PM
02WhiteGTVert
02WhiteGTVert's Avatar
Try lifting up on the clutch pedal (pulling it towards you). You have a self adjusting quadrant, doubt it will do anything though considering it's releasing at the top.
There's really not much you can do other than install an adjustable quadrant, firewall adjuster, or adjustable cable.
02WhiteGTVert is offline
Old 02-04-2012, 11:23 AM
EddyG
EddyG's Avatar
Ok so there is about and inch of play when I pull towards me. Does that mean it needs to be adjusted or is it gone. I want it to grab near the floor not near the top.
EddyG is offline
Old 02-05-2012, 07:55 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
You cannot control "where" it grabs other than within a narrow range, none of which is very "near the floor"--not that one would want it there anyway...
There should be 1" to 1-1/4" of free play in the pedal--here's a good write-up on how to use the semi-automatics adjuster, and how to over ride it to make the feel a bit better.
cliffyk is offline
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
ccdguy
09-19-2015 05:20 PM
MasterLanMan
09-13-2015 08:21 PM
Quick Reply: clutch problem.
