Best Bang for the Buck Modular Engine
Hello All,
I posted this to the general Tech forum, but didn't receive any response. So I will give it a try here.
I am starting to form ideas for a classic mustang build (67 convertible pro touring/bad a$$ car... and will start a build thread in the classic section). To make a long story short, I am done with the older style engines and want to drop a modular in it.
The budget is not infinite, but my goal would be to hit 650+ rwhp. I was thinking about dropping a 03 - 04 cobra engine in the car, but I would like to be a little different. Haven't seen a turbo charged classic mustang except for the few that are drag race cars, and think that turbocharging is the way to go. I have read in the past that pushing a 03-04 cobra over the 600 rwhp is a little bit of a ticking time bomb. So what's the best route to go?
Do I buy a 03 -04 Mach 1 engine and trans setup and spend the extra cash to build the bottom end or do I buy the cobra engine and trans setup and spend the extra to build the bottom end on that? Or do I buy a new 5.0 boss motor and turbo charge that puppy?
I would love to drop a GT500 (5.4) engine in it, but that would kill the budget elsewhere. I Would like to keep things in the $10,000 - $15,000 range. Cheaper would be better, but would like to reach respectable rwhp.
Thoughts and opinions are greatly appreciated.
Thanks
Thanks
10k for a fresh motor build plus the power adder and fuel system to support t is going to be pushing it big time, the 04 cobra swap is gonna be the cheapest way to go and u usually can get the whole setup with a trans for around 9k
I understand that view point 100%. But what has me thinking differently is, for instance, I can buy a 1999 Cobra 4v engine and trans setup on ebay. Engine has 69k miles and the whole thing is selling for $3,999.00. That leaves me $6k for improvements. With $6k can I do all the "improvements" to the engine and trans to get the car over/around 650 rwhp?
Would a stock 03-04 cobra engine be ok with 650 rwhp?
I should have stated in my original posting that my budget does not include the power adder.
As others have said, if you are gonna go used, do it right. Get a 03/04 motor and trans combo. Its gonna be around 8k, but should get you closer to your desired numbers than building a 99 cobra or 03/04 block.
Thanks everyone. I did a lot of research today and realize that going the 03/04 terminator route is the best way to go. I can meet my goal with the turbo, if i got a fuel system to support it and a good tune.
I am going to post another thread on the SVT forum to see what people recommend to do to the engine while it's out of the car.
Thanks!
Thanks!
I have thought about it, but think I am going to stick with the T56. This car may only see the drag strip once and that's about it. Since it's a convertible and since I will not be running any roll cage, I am pretty sure after one run the track officials will not allow me to run. 650 hp on a 3,000 lb car...... should be pretty quick.
