Timing Chain Problem - MustangForums.com
Old 02-17-2012, 09:58 PM   #1
cheesesticks2000
Question Timing Chain Problem
I have a 2000 Mustang GT with a loose timing chain on the passenger side. I replaced the chain and tensioner, but as I rotated I noticed the chain would get tight as it should be and then get loose again then tight and so on. What could cause this or is it suppose to do that? I wouldn't think its suppose to.
cheesesticks2000 is offline   Reply With Quote
Old 02-18-2012, 06:54 PM   #2
cliffyk
TECH SAVANT
cliffyk's Avatar
The tensioners are hydraulically loaded by the engine's oil pressure, in addition to the spring--without the engine running they do allow a bit more slack...
cliffyk is offline   Reply With Quote
2005 GT fuel problem Cin K New Member Area 4 08-31-2015 08:31 AM
crank no start 1st 4 eyed fox General Tech 2 08-24-2015 07:56 PM
1989 starting problems, engine won't turn over. KEM Motorworks 5.0L (1979-1995) Mustang 20 08-14-2015 11:13 PM
Cam swap on 68 289 ding56 Classic Mustangs (Tech) 3 08-14-2015 03:40 AM
Need Help Diagnosing Have Codes (Confused) djbigskrilla 2005-2014 Mustangs 13 08-11-2015 01:59 PM
1996, 2000, 2003, belt, chain, ford, gt, marks, mustang, oil, problem, problems, replacement, tensioner, timing
