P.I. Heads and Intake Manifold Ford Lightning to Mustang GT
Old 03-01-2012, 11:58 AM
infine0n
infine0n's Avatar
So I ended up getting the plastic PI intake manifold from the 04 GT with 45K miles, I am going to try to get the heads from the same car as well.
Is there anything else I am going to need, like an altenator bracket from a PI setup (I think I read someone you need to swap that too)?
I just very recently replaced the stock intake manifold for another non-PI intake manifold just to get it home basically. Will I be able to reuse the intake manifold gaskets? What else am I going to need besides the intake manifold, gaskets, and heads to complete the job?
I know the car is going to need some new plugs and wires as well, any suggestions with this setup? My car has 150k miles on it, but replacing the top end with 45k parts is a plus. Should I be worried about the block and transmission?
I will get into the rear end in the future. I plan to change out the gears on it.
Thank very much for the help. It is appreciated, and will be put to good use.
infine0n is offline
Old 03-01-2012, 12:45 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
you are going to need:
PI intake manifold gaskets
i just used to 2 bottom bolts for my alt i didnt even end up using a bracket, worked fine for me
new head gaskets and bolts obviously (get the Ford Racing kit off summit for like $100)
on a side note, while you have the heads off, spend the $40 and get modified intake valves from MHS
http://modularheadshop.com/Parts.htm...nd_seal_combo_
this way you can add a set of pretty decently sized cams down the road without having to pull the heads AGAIN...
theyre very easy to install btw and this isnt a suggestion... you need to do it... or else lol
sn95_331_GT_ yellow is offline
Old 03-01-2012, 02:59 PM
infine0n
infine0n's Avatar
I can't seem to find the head gasket / bolt combo on summit.. I can only find the head gaskets themselves. Do you mind pointing me in right direction?
The cut PI intake valves sounds like a good idea, I will most likely go that route because I was thinking about upgrading the cams in the future. Thanks for the heads up.
infine0n is offline
Old 03-01-2012, 04:02 PM
sn95_331_GT_ yellow
http://www.latemodelrestoration.com/...d-Changing-Kit
Old 03-01-2012, 09:20 PM
trexflyer
trexflyer's Avatar
Originally Posted by LMR
Contains all components necessary for changing cylinder heads on 1996-04 4.6L Mustang. Like new Ford head gaskets & 20 new torque-to-yield bolts. Includes 6 rubber sleeves* that make this task significantly easier. Highly recommended when installing M-6049-D46/P46/T46 cylinder heads.
*The 6 rubber sleeves included in the kit are to aid with the head bolts closest to the firewall. Several of these bolts will not be able to be removed, or installed in the vehicle, so FRPP devised a solution. The rubber sleeves are split down the middle & install over the problem head bolts keeping them suspended in the head so cylinder head removal & installation is greatly simplified!
WHAT??
trexflyer is offline
Old 03-02-2012, 05:48 PM
sn95_331_GT_ yellow
Originally Posted by trexflyer
WHAT??
you cant get the rear bolts out on the car since they either hit the brake booster or strut towers...
the sleeves are so you can put the bolts in without leaving the bolts hanging out the bottom and f*cking up the deck in the block. drop the head on, pull off the sleeves and torque them down, all there is to it.
and i did my motor out of the car so i didnt even need them...
Old 03-03-2012, 07:01 PM
infine0n
infine0n's Avatar
Thanks for the link!
I ended up winning the heads, and intake mani from the 04 GT with 45k mi. I will get back to you guys when I am ready to buy gaskets and everything else I will need.
Thanks again!
infine0n is offline
Old 03-12-2012, 06:59 PM
infine0n
infine0n's Avatar
So these is the exact parts I received:
heads:
http://www.ebay.com/itm/290675707063...#ht_500wt_1154
intake mani:
http://www.ebay.com/itm/290674430555...#ht_500wt_1154
and for the hell of it, I got a a/f gauge from the same guy:
http://www.ebay.com/itm/290675695034...#ht_500wt_1154
I'm waiting to get the gasket and bolt kit, and also the modded valves.
infine0n is offline
Old 03-12-2012, 08:17 PM
sn95_331_GT_ yellow
ATTABOY!!!! the UEGO gauge is one of the coolest things i had in my old car, everyone says its a ricer gauge, but a wideband is an AWESOME tuning tool and honestly the one i paid attention to the most
nice additions, youre gonna have a sick car bro!!
Old 03-13-2012, 01:30 AM
trexflyer
trexflyer's Avatar
thanks for clearing that up. Guess the wording of "bolts you can't remove or install" threw me off a little.
I'm getting the itch to build up my motor but I really need to rebuild the suspension first...it's getting to feel like I'm riding in a bouncy house lately.
Quick Reply: P.I. Heads and Intake Manifold Ford Lightning to Mustang GT
