Question for 4.10 auto trans owners
Ordered 4.10s and extras today, but just read that some owners with 4.10s on an auto gt have experienced very jerky shifts.
My car on stock 3.27 is already jerky but when the ford tech drove it they said it's just because the gears are incredibly worn and need to be replaced (which is why I'm taking this opportunity for a rebuild and 4.10 upgrade)
Anyone else have good experience with there auto+ 4.10 rear?
Gears generally DON'T wear out. How exactly did this tech reach this conclusion? Did he open the differential and inspect the gears?
That being said, it doesn't matter much since you are planning to install new 4.10s anyway. It could be a factor in deciding whether to let that tech perform the gear installation and clutch pack rebuild.
The jerky shifting is far more likely related to the transmission and not the gears in the differential.
GOOD LUCK and enjoy the new gears!!!
I find it nearly impossible to believe that the gears are "incredibly worn."
Note: 4:10 is horrible on the highway. Stick with the 3.73
Yeah he took the diff cover off and inspected the gears, said that's what's causing a howling whirring noise when I'm driving. Yeah I had originally thought 373 but so many people pushed me to 410 saying that it's OK on the highway. I figured just to go 65 mph my revs would be close to 2.5k revs, but everyone kept saying it's not noticeable so I chose 4.10.
How's your acceleration feel with 373? So many people on the forums kept saying they wish they did 410s so it's been like flipping quarters between the two..
Agreed that any gear interaction will cause some degree of wear, but for the factory gears to be "incredibly worn" sounds highly suspicious unless the diff was either run with low fluid, or if the gears were removed in the past and re-installed incorrectly. This statement assumes that he doesn't have 200k miles on his GT.
The factory set-up will run 200K miles without problems if fluid is maintained.
OP,
Unless you plan to go for some boost later, I would get the 4.10 ratio and not look back. Your estimate of rpm at 65mph is about right. The only chances that you will dislike the 4.10 ratio is if you do a lot of highway driving (75mph+) or if they move your cruising rpm into a band where your exhaust drones.
You will LOVE the gears!
OP,
OP,
