Where is the Vehicle speed Sensor?
Old 03-16-2012, 01:29 AM
  #21
trexflyer
trexflyer's Avatar
Damn cliffy yer the man. How do you keep up with everything since he has a 94 body, 98 trans and 02 motor? I'm already confused.
trexflyer is offline
Old 04-21-2019, 03:22 AM
  #22
Joshua Logan Oliver
Joshua Logan Oliver's Avatar
Default I have a 2002 v6 mustang with a '98 transmission in it.
Do you know how I can get my speedometer to work correctly again?
Originally Posted by cliffyk
What PCM are you running, the '98 or the '02?
I ask because the '98 VSS produces 8 pulses per sensor shaft revolution (as it is gear driven the pulses per tranny output shaft revolution will be a function of the gear ratio).
However the '02 PCM will be expecting 12 pulses per transmission output shaft revolution unless it is reprogrammed--this could perhaps throw the P0500 DTC???
Joshua Logan Oliver is offline
carlitoselcool
02-14-2015 12:02 PM
meralley
07-07-2011 09:54 PM
Mustang1994
09-04-2010 07:36 PM
peggysgirl
04-13-2008 01:49 PM
kontroldkhaos
04-24-2006 04:47 PM
Quick Reply: Where is the Vehicle speed Sensor?
