Thinking about a terminator. But first I need some help.
Old 03-14-2012, 10:49 PM
B2norma
B2norma's Avatar
Default Thinking about a terminator. But first I need some help.
I'm considering building a terminator copy from the ground up. But I know that has a lot more power then my GT. So what kind of suspension mods should I think about getting? Also should I consider changing the transmission or will the GT automatic be able to handle it? Don't try and talk me out of it. This is one of those bucket list things.
I'm using this car for the drag strip.
B2norma is offline
Old 03-15-2012, 11:50 AM
boduke0220
boduke0220's Avatar
Well what kind of budget do we have to work with and by terminator copy do you mean everything as in motor, body parts, gauges, what exactly. I won't talk you out of it I think it's cool lol
boduke0220 is offline
Old 03-15-2012, 07:32 PM
B2norma
B2norma's Avatar
Just a throw at it around $10,000 more if I have to. It will get done. I'm planning on sharing the experience with the forum(pics, dyno readings, problems, etc.).
B2norma is offline
Old 03-15-2012, 11:22 PM
SVTeeshirt
SVTeeshirt's Avatar
This is a confusing post... you're not really specifing much.... if you are talking a full drivetrain swap, your tranny will not bolt up to the motor found in 03/04 cobras... if you want a copy get a 31 spline Independent rear... which is in the 03/04 cobras... you're gonna end up spending more money turning your car into a cobra than just buying one.
my .02.
SVTeeshirt is offline
Old 03-15-2012, 11:34 PM
kast1376
kast1376's Avatar
Just buy a cobra, and swap an auto in. It has been done many times, and will cost you far less than what you want to do.
kast1376 is offline
Old 03-15-2012, 11:53 PM
SVTeeshirt
SVTeeshirt's Avatar
^ what he said... and not to mention a Cobra will be worth $10k more than a GT made to look like a cobra even if it's a copy....
Old 03-16-2012, 02:10 AM
B2norma
B2norma's Avatar
my .02.
Even tho my post was confusing you answered a few of my questions. 31 spline Independent rear sounds like a good place to start. And I am well aware of the fact that buying a cobra would be easier. I want a car that will enable me to say " I built this car from the ground up". I think what might be confusing people is I said " Terminator copy". But what I mean is an upgraded Terminator. Or lets just say building an engine with the same block and upgrading everything else.
B2norma is offline
Old 03-16-2012, 07:05 AM
MCxQubed
MCxQubed's Avatar
so your going to take a GT, then build a cobra engine, swap the irs, all the body panels, and the interior?
MCxQubed is offline
Old 03-16-2012, 05:22 PM
B2norma
B2norma's Avatar
Yeah I might be changing my mind and rebuilding my 2v. All I really want to do is rebuild my motor. I figured I world go with a 4v build but not after reading this forum. Check it out. http://www.stangnet.com/mustang-foru...-valve.780361/
B2norma is offline
Old 03-16-2012, 07:14 PM
Repzard
Repzard's Avatar
^THIS^
Repzard is offline
Quick Reply: Thinking about a terminator. But first I need some help.
