1996 4.6 idle/stutter problem, please help!
Old 03-24-2012, 12:54 AM
JC316
JC316's Avatar
Originally Posted by 9646stang
Ok we will try that tomorrow. Also there is a chattering coming from the valve covers again (passenger side) We changed the timing chain because this happend the first time, the sound never really went away after the timing chain was replaced so ruled that out. the chattering sound, sounds like a couple rocks bouncing around in the valve covers (there's no rocks in the valve cover) This car is just giving us hassle after hassle!
The noise in the valve cover is likely a collapsed lash adjuster. Pretty easy fix really. When you did the timing chain, did you change the tensioners? They too can rattle. And yeah man, I have been there before, heck I am there now with my T-bird SC.
JC316 is offline
Old 03-24-2012, 12:20 PM
9646stang
9646stang's Avatar
Yea we changed the tensioners, the chains, the cam gears, the crank gears, the rails. We changed everything. I'll look into the lash adjuster though.
9646stang is offline
Old 03-24-2012, 07:12 PM
9646stang
9646stang's Avatar
Ok, so today we got the MAF and Throttle body cleanded, the throttle body was surprisingly dirty. The chattering was the pcv valve on the passenger side valve cover... who would have thought... The hesitation is still there. We tried to get the throttle position sensor off but the screws won't budge and we don't want to strip the screws so we are going to have to find a way to get that off. We are completely stumped as to what is causing this hesitation now. This car seems to be nothing but trouble! On a side note, once you get past like 3k-3.5k rpm there is no hesitation if you stomp on the throttle. On another side note, don't test for throttle hesitation in a 25 mph zone, you will get a speeding ticket, lets add that to the list of problems this car is giving us.
Old 03-24-2012, 07:16 PM
JC316
JC316's Avatar
Huh, that is weird on the PCV. Never heard one do that before. Heat or an impact screwdriver for those screws. The hesitation you are describing is most likely the TPS.
JC316 is offline
Old 03-24-2012, 07:32 PM
9646stang
9646stang's Avatar
Yea the pcv valve wasn't secure and was pretty much just flopping around in the little hole on the valve cover. We stopped for today because we were getting frustrated with it after we got the ticket. We will try again tomorrow. Thanks for your replies they have been really helpful.
Old 03-25-2012, 07:02 PM
9646stang
9646stang's Avatar
Ok we got it fixed! Turns out the plugs were gaped too big... It was such a small problem that we completely over looked it until today. We were so mad at ourselves for overlooking this. I want to thank everybody for their help though! A lot of things you guys listed needed to be replaced anyways, such as the fuel filter, and iac sensor. A mod can close this thread now.
10-09-2015 03:27 PM
PNYXPRESS
09-14-2015 09:50 PM
rksnow1
09-14-2015 08:46 PM
rdog69t
SVT Forums
09-13-2015 06:16 PM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
Quick Reply: 1996 4.6 idle/stutter problem, please help!
