aftermarket steering wheels
#21
#22
I soldered each to thin strips of 0.040" brass flat stock to fashion terminals that plugged into the stock connector (with dielectric grease to prevent corrosion; same for the horn--that way it is all reversible if needed.
To trick the airbag module I twisted and soldered the leads of the two 4.35Ω and then crushed and shaped them so as to fit in the airbag harness connector--again all reversible is ever needed.
mungodrums
09-28-2015 10:54 PM
09-24-2015 09:18 PM
09-08-2015 11:50 AM
