Car Stutters Under Load
Was in the car the other day with some friends and the car ran great. Drove all over the place and then came home. On the way home the car just randomly started sputtering when I would hit the gas. It does it all the time under any load and only during acceleration. Car revs fine in neutral.
Fuel Pump was replaced 4 months ago.
Spark plugs and Coils were replaced 2 years ago
For some reason I have a feeling that it's a bad fuel pump AGAIN...
Any thoughts?
Any thoughts?
Check your fuel pressure, Check the plugs for any cracks.
Hook up a scanner to the OBDII port so you can see what the engine is doing under load when it sputters. If you're fuel trim goes way up, that could be a symptom of low fuel pressure and the injectors staying open longer to get the required fuel into the cylinder. Timing going all wonky would be a cracked plug since or spark leak.
Any thoughts?
Any thoughts?
Okay guys I just went to my mechanic. My Tuner wasn't throwing any codes so we used the $10,000 snap-on scanner instead LOL. Cylinders 5 & 6 were misfiring. I changed the COP's and it's all good now! Hopefully it stays that way because i ended up buying all new COP's a while back when I ruined my stock ones washing my engine bay. I re-used two of the OEM ones and it runs fine now so i'm guessing the stock ones i just put back in must not have fried from the engine wash 2 years ago.
Plugs are stock motorcraft replacements
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Daleford
08-10-2015 08:30 PM
