Another VATS related issue
Hi all
I posted this over in the 94 forum but i think i will have better luck over here.
I am currently looking at purchasing a 94 GT with a 96 4.6 v8 engine and trans swap.
However there are a few issues:
The car will start and idle for about 3 seconds then die and the theft light will flash repeatedly.
From doing some research ive found this to be VATS related
The owner bought the car and it ran fine until he broke the key off in the original cylinder. He broke the transceiver(not sure HOW it was broken other than the plastic cover being split in two.) removing the cylinder to install a new one and then put in a new transceiver.
From that point on it wont run and is now the veritable Mustang Lawn ornament.
From what i can tell, the new transceiver is not syncing the new key with the gauge cluster and pcm.
The owner has claimed he tried the following: removed the fuse #17 and had no success, tried to relearn the pcm the new key by doing the turn key wait 15 mins trick(cant honestly say i know he did it for sure)
Anyone out there think that they can help? I am working with limited funds rightnow and no local dealers want to touch it being that it is no longer "stock"
However i am wondering if the new key signal would still impact the old one negatively?
