New 4.10s shift hard
Old 03-27-2012, 06:07 PM
NewEdgeStang00
NewEdgeStang00's Avatar
The tuner has something called "shift press" and the gears, such as 1-2 2-3 and 3-4. When I go into it, it has things like 25% 20% etc. What does all that do? It's currently set at 0%
NewEdgeStang00 is offline
Old 03-29-2012, 12:44 AM
NewEdgeStang00
http://www.stangnet.com/mustang-foru...inions.553036/
found this old thread on Google. This guy is having the same exact issue that I am having after installing 4.10s. Looks like this may be an issue with any stock autos with the 4.10s. Seems to be the Torque Converter locking up.
Old 03-29-2012, 09:08 AM
uberstang1
Chupacabra
uberstang1's Avatar
Hard shifts FTW.
uberstang1 is offline
Old 03-29-2012, 04:30 PM
TRUEBLUE3934
TRUEBLUE3934's Avatar
I guess I'm a little confused about what you want from your car.
Installation of 4.10 gears implies to me that you want the car to accelerate harder. A new tune from BAMA will be set up to provide better timing curves for power and quicker/firmer shifts for less lag between gears. If the jerking that you describe is what I have always experienced with retuned auto trans, then I suggest it is fine and leave it alone. If that jerking is too harsh, then you may want to just get the trans tuning removed so you get the old wishy washy shifts back.
The fact that it won't upshift below 3000rpm makes me think that something is wrong with the tune. This condition should have nothing to do with the fact that you now have 4.10 gears.
Keep us updated on how this goes for you.
TRUEBLUE3934 is offline
Shampue
Shampue's Avatar
The fact that is won't upshift below 3000rpm makes me think that something is wrong with the tune. This condition should have nothing to do with the fact that you now have 4.10 gears.
I was under the impression he was talking with Bama to get it fixed.
Shampue is offline
Old 03-29-2012, 09:06 PM
TRUEBLUE3934
Yes, that was the last thing I think I saw from him, but he was still questioning if the shifting was in fact wrong or if it was supposed to do this.
It sounds to me like he is desiring a faster car without any loss of comfort or harshness. Reality is that typically doesn't happen. Always a trade off with performance upgrades.
Old 03-30-2012, 12:05 PM
jtb727
jtb727's Avatar
OP, with 4.10s from a dead stop, if you stomp on it, you should be able to completely break those tires loose, and HARD. I mean nothing but spinning, and it should do it all the way through first gear and DEEPLY into second gear... so if it wont do that, (you stated it feels extremely sluggish from a dead stop). Manually put the car in first via your shifter, and do it again, watch your tach, and about 4500-5k push your shifter forward one click.. and it should still be spinning through the shift.... for an example of how 4.10s should respond in your car..
when the car had the 4.10s installed, was any other work done simultaneously? trans fluid change etc? It seems weird that all of a sudden your torque converter is locking up almost immediately... mine usually doesnt lock up until im to full cruising speed for a second or two...
Keep us updated and let us know what BAMA does to your new tune. it's something with the computer, and from what you have described I dont think it's something mechanically wrong/broken.
jtb727 is offline
Thunderball
15
11-22-2015 11:49 PM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
guitarman376
09-30-2015 05:54 PM
junior04
09-28-2015 10:53 AM
Quick Reply: New 4.10s shift hard
