Opion on Putting Heads on 98 4.6 GT
Old 03-27-2012, 07:33 PM
TaylorRae
TaylorRae's Avatar
Default Opion on Putting Heads on 98 4.6 GT
I was told once you take the old heads off it messes up the block, is that true?
Is putting on new heads possible?
TaylorRae is offline
Old 03-27-2012, 08:51 PM
04camaroeater
04camaroeater's Avatar
How many miles are on your motor? You don't want to put fresh tight heads on a high mileage motor. But the answer to your question is no it doesn't mess your block up taking off the heads as long as its done properly. You would need new hardware when installing new heads however. Your old head bolts will be stretched
04camaroeater is offline
Old 03-27-2012, 10:15 PM
JC316
JC316's Avatar
Swapping heads won't hurt the block. As said, you need new head bolts, but that is a given for any head swap.
JC316 is offline
Old 03-28-2012, 07:16 AM
kugzgt
kugzgt's Avatar
it will not damage your block at all. I dont have the stock heads on mine
kugzgt is offline
Old 03-28-2012, 08:56 AM
mustangmancp
mustangmancp's Avatar
No damage here when i put my trickflows on..
mustangmancp is offline
Old 03-28-2012, 07:03 PM
TaylorRae
TaylorRae's Avatar
Thanks! And I have 150,000 miles.
Old 03-28-2012, 07:10 PM
kugzgt
kugzgt's Avatar
if anything you'd benefit from putting heads on. your valve seals probly leak at 150k
kugzgt is offline
Old 03-29-2012, 09:18 AM
uberstang1
Chupacabra
uberstang1's Avatar
Ok when doing a head swap on a high mileage shortblock its critical to run a compression check on the cylidners to determine the condition of the rings. When you have an overall high mileage motor and the rings have some wear along with the components of the head and valve train, putting on a fresh set of heads with a fresh valve job often be the nail in the coffin to a motor with lack luster compression due to worn rings. Thats what people are referring too when they say "it can mess up the motor", if your compression checks out strong there are no worries.
uberstang1 is offline
Old 03-29-2012, 04:07 PM
TaylorRae
TaylorRae's Avatar
That does make sense. Thanks!
bconboy
09-21-2015 12:52 PM
Pyrate Dave
09-10-2015 07:30 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Opion on Putting Heads on 98 4.6 GT
