Losing power/jerking WOT
My 2000 GT has recently started to jerk while accelerating. The issue seems to only start to get bad once the car warms up. It does not happen for the first 30 min of driving it. Happens in all gears and only while accelerating. It almost feels as if its sputtering or losing power. Maybe fuel related? Fuel pump or filter? Just looking for some advice on where to start.
Thanks
Thanks
I am experiencing this issue right now too... From around 1500 to 2200 RPM I feel a shuddering under 1/2 to WOT In each gear as if a cylinder wasn't firing hard enough. I'm pretty sure I have a bad cop. It seems to be firing sometimes and when it does it's really weak. It doesn't seem as bad under light acceleration but if I got past 1/2 throttle its really noticeable. I've swapped out all my fuel injectors and still same issue so it's not that. I doubt it's my fuel pump either bc every other cylinder is firing correctly. I'm pretty positive I have a bad cop so I it a whole new set coming in. I would maybe check yours. I tested mine with the ohm meter an they all tested out ok but I think mine is just really weak so it could have tested ok. I'm not 100% sure but this is where I've landed after tryin different things. Hope it helps.
