PTV clearance questions
Old 04-04-2012, 01:28 AM
mtang98 gt
mtang98 gt's Avatar
Default PTV clearance questions
I just purcahsed windsor cnc ported heads with oversize stainless valves, 600lb springs and cnc stage 2's heart shaped combustion chambers. i think 44cc. And im trying to figure out what cams would be safe to run, so any types of cams you guys recommend?
These are the sets of cams i have been looking at.
http://www.americanmuscle.com/mustan...s-xe270ah.html
http://www.modmaxracing.com/product_p/37011460-79.htm
http://www.modmaxracing.com/product_p/37011460-69.htm
http://www.summitracing.com/parts/TFS-51802002/
My real big concern is that I want to be 100% no worry about the PTV clearance, just incase the springs arnt really 600 lift springs...is there any way to check if they are?
Any help is appreciated thanks
mtang98 gt is offline
Old 04-04-2012, 09:57 AM
kugzgt
kugzgt's Avatar
you may want to go with a custom grind cam. check out www.modularheadshop.com
there are a few of us on here running mhs cams (including myself) and we have no complaints. they have tons of cams for different applications.
kugzgt is offline
Old 04-04-2012, 07:49 PM
mtang98 gt
mtang98 gt's Avatar
Arnt custom grind really pricey?? I'm only Lookn to spend a max of $550
Old 04-04-2012, 08:02 PM
kugzgt
kugzgt's Avatar
$600. Which is totally worth it. The stage 2 cams don't require aftermarket valve springs. That'll save you money right there.
kugzgt is offline
Old 04-04-2012, 11:18 PM
mtang98 gt
mtang98 gt's Avatar
Sent him an email.. the stage 2 cams are lookin pretty good.
Old 04-05-2012, 08:29 PM
mtang98 gt
mtang98 gt's Avatar
Well I talked to nick and he said that I could run the stage 3r cams becuase I have after market valves . But I wondering if it is really necessary to degree the cams? I don't really have the money to pay for the additional service and unfortunately I don't know how to do it myself.
Old 04-07-2012, 06:59 AM
kugzgt
kugzgt's Avatar
you most definitely want to degree those cams. do exactly what nick tells you. the guy knows his stuff. if you can't afford to do so, then you should just wait until you have then funding for it. if you build it the right way, you only do it once.
kugzgt is offline
Old 04-07-2012, 04:12 PM
mtang98 gt
mtang98 gt's Avatar
Yeah I'm gonna save up get the stage 3 cams then get the degreeing service also with the oem cam gears
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: PTV clearance questions
