clutch pedal hardness on auto to manual convert
Old 04-08-2012, 09:47 AM
Warrior1876
Warrior1876's Avatar
Default clutch pedal hardness on auto to manual convert
I had my 01 mustang converted to a stick shift. The pedal is a rock and even had a new dual friction centerforce clutch installed. The model trans they used i believe is a 1999 not a 2001 for my car. I believe it should have a 3850 in it but has the model before. Can that have something to do with the hardness of the pedal. I tried 2 different clutches and i am just unhappy with it. I am thinking about converting back to auto but really dont want to spend the money. Any ideas why the pedal is so hard. My brother has the same year car and the same clutch and its much lighter.
Warrior1876 is offline
Old 04-08-2012, 10:15 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Does the car shift/drive properly? If the clutch is soo stiff, maybe there is resistance in the cable or something. I am not familiar with the pedal pressure required to operate a Centerforce dual-friction clutch, but should not be as difficult as you describe.
How does it compare to other clutches you have used?
Jazzer
Jazzer The Cat is offline
Old 04-08-2012, 11:40 AM
Warrior1876
it shift fine its just real hard to push the clutch in. It was a little better when i got the centerforce clutch but not much. I feel like there has to be something wrong.
Old 04-08-2012, 12:32 PM
Warrior1876
I really need some help so if anyone has any ideas please let me know. Thanks
Old 04-08-2012, 01:56 PM
JC316
JC316's Avatar
Mustangs are naturally stiff, so it may be normal. My mustangs were insanely stiff compared to my Fireturd and my Thunderchicken.
JC316 is offline
Old 04-08-2012, 04:06 PM
Warrior1876
Thanks Man, i have been in other stangs with mods like mine and none where near as stiff as mine. Its not even close. I didnt know if it was the trans model i have or what but its just not fun to drive.
Old 04-08-2012, 04:19 PM
JC316
JC316's Avatar
Sounds like the clutch fork might be binding up, that or you have a cable/quadrant issue.
JC316 is offline
97SN95GT
09-13-2015 09:45 PM
Jskeezy84
09-08-2015 01:40 AM
whatsup62
09-03-2015 01:38 PM
iculookin
09-02-2015 12:34 PM
Quick Reply: clutch pedal hardness on auto to manual convert
