lug nut of doom!
lug nut of doom!
As the title says, i have an evil lug nut lol, i got my new lug nuts today with my aftermarket TB spacer, and i got to the front passengers side, and one lug nut barely loosened and now it just spins and wont tighten or loosen, and i have noooo clue how to fix it at all =/
eeehhh?!?!? change the stud O.o please explain on how one does this? also, will it be safe-ish to drive as is? or completely hazardous to me health
(Oh hey, your from my home state, il be back home may 18-28)
How too in a short
take off wheel
take off caliper.(2 bolts)
remove pads (slide out)
take off caliper bracket.( 2 bolt back side)
side off rotor.
tap out stud.
slide new stud in (stack up about 5-8 washer or use a big nut and tighten lug nut on new stud and it will suck it in)
heres a vid that may help http://www.youtube.com/watch?v=gy9t1mU0lG0&feature=fvsr
reverse process
it would but would take forever, it's easier to just put a screwdriver or something behind it while you turn it off, after it gets started off, it should come on off
just tried applying pressure to it from all angles, even used a impact gun on the SOAB but no good, didnt even loosen a little, just loads of spinning, looks like its drilling time, if you guys have any more advice i recomend sending a message to my phone, otherwise i wont get it till i'm done, thanks for the help though.
Cell: 580-465-4709
Ethan~
Cell: 580-465-4709
Ethan~
wel;l drilling failed and i ended up fudbar'ing the lug nut, and now im stuck, way to go and **** everything up me. woo --,-- guess its mechanic time, and he'l prolly tell me to gtfo
Edit: I appoloize for said drama queen moment lol. went to lowes got new drill bits and it worked loads better and i fixed it all yay
