Squeaking when I turn
I have a problem that is driving me crazy, my 02 GT squeaks loudly when I turn at low speeds and hit bumps, brake as well. I changed out the power steering pump before I deployed last year, but that had little to no effect. I was wondering if it could be the steering column or ball joints, or something else I might be overlooking. Any help would be appreciated.
Where can I find the tool to do this? I would like to try this first before buying new ones and having them pressed into place.
Almost any FLAPS will have one of these or similar in stock:
Clean the joint's boot well with a mild degreaser, then inject a bit of grease (not so much as to puff up the boot a whole bunch). Then if you want to seal the puncture re-clean the boot and apply a small dab of RTV sealant.
You may also wish to check the steering rack tube brackets, as described here...
If it was me I would change them, if not one day you'll be stuck somewhere. Mine did that and it was a very short time before my ball joint popped and the control arm slammed to the ground. Thankfully enough mine did it just as I was pulling from in front of my house and I was able to get it up on a jack and push back if front of my house. If that thing was to fail going down the highway it's going to cost a ton of money to fix everything that's going to get ripped apart when it slams the ground. Just my .02
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
logan409
09-26-2015 07:43 PM
